Like Tree34Likes
RC10B4/T4 Forum
Old 08-22-2005, 08:29 AM
  #541
Tubaboy's Avatar
Originally Posted by Ophidian
Does anyone know what spring and oil weight to start at for a very bumpy track. They run 1/8 buggies on the same track.
For Buggy, try 35 all the way around. Our track is bumpy, and hashigh jumps (2-3' high)
Try Green or Silver springs in the rear. In the front try anything from Black to silver springs. Depending on traction. The softer the spring the more steering you'll get entering a corner. The stiffer the spring the less entry steering, but you'll get more acceleration out of the corner.
For truck, 35's and stock springs should do the trick.
Tubaboy is offline
Old 08-22-2005, 09:25 AM
  #542
Instead of advice, I give you some links:
Slippery & Rought Track
ROAR Modified Off-Road Nationals Low traction & bumpy track
Neil Cragg - Euro 2004
Neil Cragg - World 2005
The track for the EC '04 and WC '05 are the same, (very) rought and (very) slippery
Arn0 is offline
Old 08-26-2005, 02:20 PM
  #543
jamescam's Avatar
Default Cleaning Carbon Pieces?
I have stripped down my B4 to give it a good cleaning and upgrade some parts and was wondering what to use to clean the carbon parts. Will soap and water work or should I not get them wet?
jamescam is offline
Old 08-26-2005, 02:46 PM
  #544
nutfluff's Avatar
Soap and water is fine. You can even add a little simple green to the water if you like. However, use motor spray to blast dirt out of the metal parts.
nutfluff is offline
Old 08-26-2005, 03:08 PM
  #545
Scott S's Avatar
Trader Rating: 30 (100%+)
Use Pledge (wood furniture cleaner) to clean the parts and get them looking new again. It works amazing.
Scott S is offline
Old 08-28-2005, 11:42 AM
  #546
jamescam's Avatar
Default Building the dream T4
Before I put together my T4 Factory Team kit I am trying to think of any performance hop ups (as this will be my race vehicle performance is more important than looks for this project) that will help me get around the track faster. If money was no object what would your dream T4 be (I will be racing stock):
ESC - Quantum 2
Servo - Airtronics 452
Motor - EAMotorSports Monster Pro
Receiver - Spektrum
Chasis - Downgrade to Plastic
Other Hop Ups:
- Stainless Steel Screw Kit (How much lighter is titanium and is the Lunsford worth it? I bought a knock off titanium set for my B4 and it was crap. I like the bling, bling of the Stainless Steel).
- RPM Black Gear Cover
- Lunsford Titanium Hinge Pins
- Lightweight Outdrive
- Blue Aluminum Shock Caps (are these a benefit or for looks only)
- Battery Strap Thumbscrews (best upgrade ever made for under $10)
- RPM Front Bumper (not large bumper but bigger than stock)
Was thinking of in-line axles but I'm not that good of a driver. Did I miss anything? Should I go with the S9451 over the Air 452 Servo? Your input is appreciated.
jamescam is offline
Old 08-28-2005, 04:56 PM
  #547
Scott S's Avatar
If your racing stock, try and reduce rotating mass. That will help your lap times more then anything else.
-Lighter slipper pads
-Titanium top shaft (if anyone makes one yet) or Machined down top shaft (saw it custom made on a site linked here not long ago, I'm sure someone has a link).
-Aluminum CVD's
-Lightweight pinions
-Aluminum screws (looks and less mass)
Anything else you can find to make the car light.
Scott S is offline
Old 08-28-2005, 05:18 PM
  #548
WheelNut's Avatar
How long do you think it would take to build a FT B4? I'm going to order one tommorow and it wont get here until wednesday. I'll only have 2 evenings to complete the whole thing, including the body and everything. I had a T4 for a year and a half so I know how increadibly easily the 4 series cars go together. But I never built it from the ground up. I'm thinking it shouldnt take more than 4 hours to do the whole chassis, not including gluing tires or painting. What do you guys think?
WheelNut is offline
Old 08-28-2005, 06:10 PM
  #549
Nick111's Avatar
It took me about 2 hours to build the kit. Figure a half hour for tires and another half hour for the body. 2 days is plently of time to build it.
Jamescam- The FT kit comes with lightweight outdrives, With a mod motor I got just about 3 weeks out of a set, so with a stock they should last quiet a while, but I would have a backup set just incase you snap one. The GT heavy duty ones are great, and last forever, but wear might not be that big of an issue in stock.
Scott- You left the plug for your powersupply at the track last sunday when you left, I have it and was going to give it to you friday but you weren't there, and i'll be at Vineland this week. So if your looking for it, I have it in my box.
Nick111 is offline
Old 08-28-2005, 06:31 PM
  #550
schmelme's Avatar
http://www.speedysracingparts.com/id20.htm
Lightened top shaft and gears. Not sure of durability on high bite tracks though.
schmelme is offline
Old 08-28-2005, 07:24 PM
  #551
JoshR 85's Avatar
HeY!!!
No offense but it should take ya longer to put the kit together to take your time on it and make sure everything goes together nice and smooth and parts are free, and shocks are smooth and so on.... theres so much stuff to do to the kits as you build them to make it perform better....
LaTa JoSh
JoshR 85 is offline
Old 08-28-2005, 07:33 PM
  #552
jamescam's Avatar
-Aluminum CVD's
Any links for lighter slipper pads or aluminum CVD's? Found aluminum screws at Tracksiderc.com, am a little worried about durability but we will try it and see. LHS sells aluminum pinions.
jamescam is offline
Old 08-28-2005, 10:12 PM
  #553
Default What mods to make...
New to RC, just got T4SE. I've replaced servo with Hitech 645 (after rebuilding stock 3 times!). Replaced motor with Trinity 15 turn. Was wondering, in what order should I start replacing parts, and what parts do I need to replace to make this truck "race ready"? I realize I first need to learn how to drive it and keep it on the track, but as my skill increases and my wallet allows where should I make my investments?
Thanks in advance,
Dave
Sharkandawe is offline
Old 08-29-2005, 12:39 AM
  #554
MadMikeB's Avatar
Hi James,
Two comments:
1. I have two of the RPM gear covers, and neither seals as well as the AE FT one. I would stick with the stock one in future.
2. I would build the shocks using the Yokomo "bleeder" caps instead of either of the AE caps. The convenience when you're filling the shocks is a time saver, especially if you're under pressure or in a hurry.
MIKE
ESC - Quantum 2
Receiver - Spektrum
Other Hop Ups:
MadMikeB is offline
Old 08-29-2005, 12:51 AM
  #555
jamescam's Avatar
Originally Posted by ozdork
Hi James,
Two comments:
MIKE
1. That is a good point. I know AE puts out a black gear cover as an optional part so I will go with that one instead if I want to go black.
2. Good idea, for $3 definately something i will pick up.
jamescam is offline
