Like Tree34Likes
RC10B4/T4 Forum
Old 09-09-2008, 02:39 PM
  #5356
Tech Legend
Wild Cherry's Avatar
Originally Posted by Tater salad View Post
Hmm havent heard of this one, kinda similar to putting a little bit of droop spacers under the pistons? But i guess it would change the shock angle slightly.
everything feels the same cept if you dive to deep into the turn its softer, delivering less hook or square off in the apex ....
more forgiving...
Wild Cherry is offline
Old 09-09-2008, 03:22 PM
  #5357
Kings Kid's Avatar
Trader Rating: 35 (100%+)
Originally Posted by mr_bungle View Post
Oooook, let's say I was buying $20 worth of items from a local track. What would you recommend?
I will be supporting my local track via practice and racing fees. I understand what you're saying, but I have to imagine I'm probably not the only one who is buying a vehicle online.
rpm makes a set of arms and bulk head for the 1/10th scale gas truck that work very nicely on the t4. Pretty much makes the front end bullet proof!
Kings Kid is offline
  #5358
Tubaboy's Avatar
78 Spur gear if you're using a 17.5 motor. Then throw on a big pinion gear
Other than that, if you're getting the team kit, get the aluminum front hinge pin brace, Heavy Duty Servo Spring, and FT Servo Saver Bolt.
Paul
Tubaboy is offline
Old 09-09-2008, 09:41 PM
  #5359
Jake S's Avatar
Trader Rating: 67 (93%+)
selling a pair of johnny's lipo weight plates (OCD RACING) sold my t4/b4 so no longer need these, ran with the 4800 for awhile, and hooked up great with the "factory-stock" setup.
Jake S is offline
Old 09-09-2008, 09:54 PM
  #5360
Jake S's Avatar
sold pending.
Jake S is offline
Old 09-11-2008, 04:30 PM
  #5361
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 93 (100%+)
I am ordering a FT B4 and FT T4 from my LHS.. How will they be able to distinguish the old Factory Team kits from the new ones? Is there a updated part number for each kit? I dont want to be stuck with the older kit like last year when I purchased one in Jan or 08
I know the box for the B4 changed it color to BLack.. did the T4 as well?
Does it say 20th Year Anniversary on both boxes?
BSchorr is offline
Old 09-11-2008, 04:36 PM
  #5362
Jake S's Avatar
as i said YES...
http://www.aeforums.co.uk/forum/index.php?showtopic=203 (since you don't trust me lol)
Jake S is offline
  #5363
carbon madness's Avatar
It was a running change, so all the new kits are the updated ones. The part #'s are the same.
As long as the kit is ordered, then chances are it is the black box version (the only way you would get the white box is if the kit was sitting in a storge room for a long time)
carbon madness is offline
Old 09-14-2008, 07:13 AM
  #5364
BSchorr's Avatar
Hey, what does the updated u-brace do? Im having a brain fart! Is it for the B4/T4 or just the B4?
Anyone have Ryan Cav's 2008 CRCRC setup for B4/T4?? AE lacks to update their site!
Also, what colored springs come in the FT B4/T4 kits?
BSchorr is offline
Old 09-14-2008, 11:45 AM
  #5365
Tubaboy's Avatar
It's thicker. So when you look at setups, it's already considered to have 2 washers on it compared to the old version. Made the part a lot stronger.
B4 Comes with Black Rear/Brown Fronts.
T4 comes with Silver Rear/ Green Fronts I believe.
Paul
Tubaboy is offline
Old 09-14-2008, 11:46 AM
  #5366
BSchorr's Avatar
T4 has silver fronts, green backs.
and thanks.
BSchorr is offline
Old 09-14-2008, 03:58 PM
  #5367
What "U" brace are you guys referring to.
Tater salad is offline
Old 09-14-2008, 04:02 PM
  #5368
BSchorr's Avatar
This...
BSchorr is offline
Old 09-14-2008, 05:33 PM
  #5369
aeRayls's Avatar
AE doesnt update their setups anymore because they dont run anything new. You'd be surprised how not close the setups are to what they really ran at a particular race. Just start with cav's latest hot rod setup and go from there.
aeRayls is offline
Old 09-14-2008, 07:53 PM
  #5370
BSchorr's Avatar
Ya, Im starting with his Trackside 2007 setup.
Last year, I was running a Losi CR Buggy, was having troubles with the way it worked. So at the big race, I bought a FT B4, Built it, put RC's Trackside 2007 setup on it, didnt get a chance to practice at all with it. I TQ'd 5 seconds over from 2nd place, and also picked up a lap from my Losi CR Buggy. When I set that TQ, the track was wet, so i was running pink taper slicks. But then the track continuted to dry out, didnt have the right tires (Pink BK Bars in the rear) and no one came close to it! But later to find out, The changed it from Rocket round qualifing (One best race) to best 2 out of 4 races. I had some bad races. So ya.
Ill post pics when im done with the cars!
BSchorr is offline
