Like Tree34Likes
RC10B4/T4 Forum
Old 09-07-2008, 10:49 AM
  #5326
I won't say it again, I race with a cover, I don't have a problem marshalling cars without them.
Creature is offline
Old 09-07-2008, 11:06 AM
  #5327
chewiefttc4's Avatar
Trader Rating: 26 (96%+)
Originally Posted by ray3619 View Post
no gear cover at our track means no marshalling , and sometimes a beat downjk , we have had a couple of nasty things happen to young fingers
im not a retart who likes to be on throttle while marshalling. if the marshall doesnt see it ill give it a good wanging and then instantly hit the brakes when they see it.
i normally run a gear cover but when somone t bones you and bends it in during a race and its rubbing on the spur horribly i tend to toss it out and contiue on with my day
chewiefttc4 is offline
Old 09-07-2008, 11:09 AM
  #5328
holy triple post
Old 09-07-2008, 07:54 PM
  #5329
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Just be carefull, when someone T bones you without a gear cover, you'll end up needing a spur very often.
More steering....
Any of these are worth a try, one at a time.
Raise the front spindle
Less anti-squat
Less aggressive rear tire
More aggressive front tire
Shorter rear camber link
Longer front camber link
Raise outer camber link in rear/lower inside
Raise inner camber link in front /lower outside
...Jim
W.E.D.
W.E.D.Jim is offline
Old 09-08-2008, 04:00 PM
  #5330
hanzo3's Avatar
Trader Rating: 55 (100%+)
Does anyone use a LRP Sphere TC in the B4? Could I take the fan off? Why does the regular sphere not have a heatsink/fan?
hanzo3 is offline
Old 09-08-2008, 04:55 PM
  #5331
idbdoug's Avatar
Trader Rating: 38 (100%+)
Is there any special parts/bearing required to mount a GT2 Rear Hub Carrier on a T4?
idbdoug
idbdoug is offline
Old 09-08-2008, 05:02 PM
  #5332
Tech Legend
Wild Cherry's Avatar
idbdoug
You will need
2 #7935 bearings
2 #3977 bearings
1 set of #7981 Gt 2 rear hub
1 set of #7933 bearing spacer ( B-4 spacer will not fit )
Wild Cherry is offline
Old 09-08-2008, 07:49 PM
  #5333
W.E.D.Jim's Avatar
hanzo3, I use the TC version in any vehicle that the fan will clear. It isn't needed for offroad and was added to the TC version since they sometimes run 3.5 turns, lol.
It is better in all cases, but since it might not fit well, it is fine for offroad without the fan.
Hope this helps!
...Jim
W.E.D.
Old 09-08-2008, 08:00 PM
  #5334
idbdoug's Avatar
Originally Posted by Wild Cherry View Post
You will need
2 #7935 bearings
2 #3977 bearings
I show #7932 as the part # for the -1.5 toe in GT2 hubs
For #7933 is listed as GT2/B44 Bearing Crush Tube.
Are these the items you are referring to on your post
Thanks for the info
idbdoug
idbdoug is offline
Old 09-08-2008, 08:21 PM
  #5335
I just ordered and received one of these. It is a cover that allows you to adjust the slipper without a wrench. 20 bucks delivered to Canada and here in less than 2 weeks.
http://www.rogueelementcomponents.com/scabs.htm
easiest thing I ever bought on the internet.
Cammer is offline
Old 09-08-2008, 08:30 PM
  #5336
that was completely random.
Creature is offline
Old 09-08-2008, 08:51 PM
  #5337
ill take random and useful over random and useless anyday
Old 09-08-2008, 09:02 PM
  #5338
got me there.
Creature is offline
Old 09-08-2008, 09:05 PM
  #5339
we need a lipo/brushless oriented t5 and b5
Old 09-08-2008, 09:26 PM
  #5340
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 93 (100%+)
Anyone got some dialed setups for me to run on my B4/T4 on an indoor high bite track where we use ground down tapers when its wet, and then front tapers and rear bk bars when it dries out?
BSchorr is offline
