Like Tree34Likes
RC10B4/T4 Forum
Old 08-12-2008, 10:03 PM
  #5161
rgrg2's Avatar
Trader Rating: 48 (100%+)
Thanks Stagger2. I will try resetting the ESC. Probably won't find anyone with the same radio. I will try the motor caps and newer batteries also. Would it have anything to do with the antenna?
rgrg2 is offline
Old 08-12-2008, 10:10 PM
  #5162
Stagger2's Avatar
It could, did you shorten the new ant., did you put it in or someone else? if you cut it, that will cause you problems each band has an optimal length that is best changing this is not a good idea, if when soldered in, the solder joint was bad or "cold" it would not make a good contact or a lick of solder could make contact elsewhere on the board itself causing the issue.
Chad O
Stagger2 is offline
Old 08-13-2008, 08:52 AM
  #5163
wed jim how long did it to paint those bodies
devin4444 is offline
Old 08-14-2008, 10:09 AM
  #5164
gijoe64's Avatar
Trader Rating: 30 (100%+)
Hello guys I need some gearing help for my T4, I'm running on a large dusty, slippery, bumpy track. I am using a Novak 7.5 Light motor but I switched to a 13.5. Last week while using the 13.5 it felt better and lap time improved but Im not as fast as I need to be I want to put the 7.5L back in but I am have some control problems in the corners what gearing do you guys think I should use for the 7.5L. I have also been using the Slippery Track setup for the T4 and it works ok but I think it needs more work.
gijoe64 is offline
Old 08-14-2008, 06:20 PM
  #5165
Tech Legend
Wild Cherry's Avatar
Suggest a 23/87 or 24/87
Wild Cherry is offline
Old 08-14-2008, 06:47 PM
  #5166
racer x 1's Avatar
Trader Rating: 27 (100%+)
suggested gearing for a 8.5 novak in a b4... will be running at ocrc.
racer x 1 is offline
Old 08-14-2008, 06:52 PM
  #5167
Tech Legend
B-4 8.5
25/78
Old 08-14-2008, 06:55 PM
  #5168
racer x 1's Avatar
thanks. do you think i can get the hot set-up for the new layout?
Old 08-14-2008, 07:00 PM
  #5169
Tech Legend
For set-up help & advise
review the Team set-ups on
www.Rc10.com
www.ocrcraceway.com
Old 08-14-2008, 08:34 PM
  #5170
tom_chang79's Avatar
Has anyone done this mod to their B4's front end?
http://www.rc10b4.com/forum/showthre...t=b4+front+mod
I did this to a B4 I used to have, has Proline fixed their wobbly-wheel issue?
tom_chang79 is offline
Old 08-14-2008, 08:39 PM
  #5171
Tech Legend
Ae molds there own wheels now ...
Old 08-14-2008, 08:51 PM
  #5172
UN4RACING's Avatar
Trader Rating: 22 (100%+)
How did that effect the bump steer? Looks like maybe they should be inverted.?
UN4RACING is offline
Old 08-15-2008, 05:39 AM
  #5173
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
cherry you make that sound like a good thing. I have had nothing but bad luck with the new AE wheels on my T4. they like to crack in the tire bead area where you glue the tire.
2wdMod is online now
Old 08-15-2008, 08:15 AM
  #5174
gijoe64's Avatar
Hello again, I have an question about the quick change rear wheel conversion for the T4. Will I need to get GT2 rear arms? I run the GT2 front end on my T4 what will the rear end conversion do for me?
gijoe64 is offline
Old 08-15-2008, 08:41 AM
  #5175
Mertz's Avatar
ASC7988 is the part number to convert your t4 to quick change. You use regular t4 arms and everything, nothin changes just the axle is now the posi-lock attachment.
Mertz is offline
