RC10B4/T4 Forum
#483
i for got springs, the rears will be the same however the front's are different
#484
The T4's chassis is longer then the B4's so you would need a new chassis if you wanted to race with your converted B4.
Just one question before i go, how does the FT B4 hold up if you gave it the occasional bashing?
Thanks.
Sean
Thanks.
Sean
#485
along with the chassis you will need tires, bearings are the same though
and front body mounts as they are seperate from the tower
as for bashing it really depends on what to do to it, i could say it might hold up but its really more a of a race car, you might break something but parts are usually easy to come by
#486
Originally Posted by nwilcox88
Here is the part number. I know I had a heak of a time locating them, call your LHS. I have never used the blatters.
#487
Thanks.
Sean
Thanks.
Sean
#488
It might be cheaper to just buy a second hand team T4 roller for parts.What do you say?
Sean
Sean
#489
Deffinatey a good idea for parts, any used roller is good for spares. i think the B4 could be used as a basher as long as you dont go too crazy just have a few a-arms and bulkheads spare.
#491
I have an issue I thought was fixed but now a new problem has surfaced.
I race on a hard/medium pack track that is dusty. I have my T4 running good in most areas in the track but having a problem getting it to handle properly when it makes the switch from Dusty (loose) banked turn to hard pack straight section. Going down the fast stregth away the back end wants to drift around.
In this picture the area I am mostly having problems is coming out of the banking.
but not limited to just this area, mainly this turn is were I loose most of my track time. The biggest concern I have is another ahrd crash like a couple weeks ago were I had to replace the front end, dont want that happeneing again.
Tires I am running are step pins, they work great in the loose areas. I did pick up a pair of Bow Ties today to try next race day. I would loike some knowledgable ideas as well.
#492
HeY!!!
Red Z your best bet would prolly be about 25-30 in front, and 30-35 in rear... unless thats just the hot setup at trackside and leisurehours but you could start w/ that.... maybe play around w/ the shock limiters.
#493
Red Z-- usually when i travel i'll set my car symetrical front to rear, for a high traction i'll put them to 35 and 1's or 30 and 2's with blacks all around for a loose track i'll start around 30 and 1's and blacks all around with a half ounce in the rear, and then tune from there, hope this helps
nwilcox88--try loosening ur slipper , if its only come on power hard like coming onto a straight loose the slipper a little and see if that helps any
#494
#495
Ye thats one hell of a track some good jumps and the surface looks imaculate
