Like Tree34Likes
RC10B4/T4 Forum
Old 07-04-2008, 04:09 AM
  #4921
Drifting101's Avatar
Originally Posted by badassrevo View Post
yes it will.
Cheers just ordered some
Drifting101 is offline
Old 07-05-2008, 02:45 PM
  #4922
Trader Rating: 19 (100%+)
Does anyone have some gearing advice for an 8.5 in a b4 on a tight track. (OC/RC raceway) track is 60' x 90'. Thanks
Chris Brown is offline
Old 07-05-2008, 06:49 PM
  #4923
Tech Legend
Wild Cherry's Avatar
Default Suggestion for Lrp X-11 8.5
14 rotor
25/78 <> 26/78
12.5 rotor= 25/78
Wild Cherry is offline
Old 07-05-2008, 08:55 PM
  #4924
Cool thanks again.
Old 07-06-2008, 06:40 PM
  #4925
Hi all,
Tire question: I'm looking for a rear truck tire that has similar traction characteristics to M3 Step Pins but wears better. I race on a track that can get lots of small dirt chunks on it as well as getting really rough and choppy. When the track is swept off, it's hard and has plenty of traction....super soft Switches work really well then. Any ideas? Bow Ties don't have the side bite that I'm after and the Step Pins wear to fast for my liking. I was thinking of Panther Komodo's in either soft or super soft but haven't tried them yet. Any other options I should consider? Thanks in advance!
adam lancia is offline
Old 07-06-2008, 07:02 PM
  #4926
AssocRacer's Avatar
you are describing a track that i test and practice at. I just tried a set of the kit tires (M3 Holeshots) and they were HOOKED UP. Remember, when you race on a track that has a hard surface, you need a softer tire. Unfortunately, the softer tire will wear out faster. If you want good traction, then go with softer tires. If you want good tire wire but want to sacrifice traction, go with a harder compound pin type tire.
AssocRacer is offline
Old 07-06-2008, 07:39 PM
  #4927
Kings Kid's Avatar
Trader Rating: 35 (100%+)
we're running on a simular surface and the J concepts goosebumps are working very well.
Kings Kid is offline
Old 07-06-2008, 07:50 PM
  #4928
AssocRacer: Holeshots are a no go, 2 runs and they're missing pins from the sand and rocks. They work well when the track is mostly swept but not well enough to justify a new sets every other battery pack. I've been racing a while and am familiar with the hard surface/tire compound relationship. What I'm after most is tire tread options that yield similar traction to Step Pins (which Holeshots don't when the track is really loose and lumpy/choppy ) but with better wear.
Kings Kid: I'll look into the Goosebumps, how are the compounds rated? I know there's blue, green and yellow but I forget which is soft etc...?
Thanks guys!
Old 07-06-2008, 07:54 PM
  #4929
Kings Kid's Avatar
Thanks guys!
green is the soft compound, it's very soft
Old 07-06-2008, 07:56 PM
  #4930
M3/Red/Super Soft compound soft or softer...? Thanks!
Old 07-06-2008, 07:57 PM
  #4931
Trader Rating: 28 (100%+)
Panther studs in soft compound, foams that come with tires. Love those tires, long lasting and hook up on many surfaces.
jbrow1 is offline
Old 07-06-2008, 08:08 PM
  #4932
Tubaboy's Avatar
Losi T-Bones may work well for you.
Paul
Tubaboy is offline
Old 07-07-2008, 04:57 AM
  #4933
dirtdustingdavo's Avatar
Trader Rating: 18 (100%+)
Any pinion starting suggestions for a T4? Running small tight track, with a 19 single. Currently have a 21 pinion with a 87 spur, every thing else is box stock factory team set up.
dirtdustingdavo is offline
Old 07-07-2008, 08:21 AM
  #4934
Mertz's Avatar
You can prob. go with a 18 or 19 tooth, that should be fine.
Mertz is offline
Old 07-07-2008, 12:57 PM
  #4935
Tubaboy's Avatar
I run a 17T with my Komodo Dragon 19T.
I can probably go up to an 18, but our straight is small, so 17 gives me more torque out of the turns.
Paul
Tubaboy is offline
