RC10B4/T4 Forum
#4906
#4907
I am very pleased with my trinity lipros 4500...
#4908
I went for the REEDY~S 5000 (purchase 2)
Got to grind the rear tower a bit so they will fit with the thin weight underneath ....
#4909
Hey guys!! I've got a racing setup question. At my track I am running stock truck. Obviously I have the T4, but it is the FT.
The problem I am having is that I am real loose in the corners and even sometimes down the straightaway. I am running a stockstar with an Orion carbon cased batt, holeshpts on the rear, which is what is being run by all of the fast guys there with "Edge" fronts. I am also running the stock suspension setup.
Please guide me in the way of traction!
#4911
Did you loosen your slipper and mabe diff adjustment, I would not change suspension setup until you re-adjust your slipper and diff. Question does the truck jump good? And are you rolling the corners or breaking hard and getting on the throttle?
#4913
#4914
With a low turn mod motor you don't need the punch as much but with the 10.5 you feel the difference.
Get the 3600 1 or 2 if you wanna have a spare when you practice, I use one 3600 for 1 night of racing with 6 min quali's and 8 min main. I just top it off. works like butta.
I was waiting to get the 3800 but i hear it's the same so i am getting the 3600's when i get the cash.
#4916
Since I was running Lipo I added some weight to the chassis, 1 oz under the shock tower, .5 oz on each side of the back of the chassis (in the little slanted kinda chassis support thingies), and another .5 oz on the front(again in the little slanted kinda chassis support thingies). That is was what the fast guys at my truck are running and thought I would give it a shot. Since I was having so much trouble with traction I thought maybe adding a brick onto the back, LOL.
The truck jumps awesome and I am rolling through the corners so I guess I am just giving too much power to the back wheels and spinning them out. I even had the idea of turning the throttle down on my controller. It helped but then I ran like a stock motor in dire need of a comm cut. Makes sense. Next time I get to the track I will loosen the slipper up a turn or two and see how that goes.
Thanks for the input.
#4917
#4918
you will need to add some weight to your truck. You don't necessarily need the full 5-6ozs but a couple will make a big difference. using 6 of the7 gram stick on lead weights, attach them to the front of the rear arms carrier (9571) in the very back of the battery tray. That will place the weight just in front of the rear axle. If you go to the associated website and look at the factory guys setups for low grip tracks, they all run at least an oz and a 1/2 back there. After your sure on your diff and slipper setups, Then I'd look at shocks or camber links. My .02 for slick tracks.
