RC10B4/T4 Forum
#4877
Start with Pro-Line M2 ft tires & Snake Eyes for the rear
Also try Pro-Line Holeshots for the rear.....
#4878
Bowties have been working well for at my track...it's gets fluffy...dusty. I've tried the JC goosebumps also...seem about the same when dusty... when the track is holding more moisture they seem to have a slight edge over the bowties. my 2¢
#4879
Steppins are not as good at my track either compared to the bow or goosebumps. Not loamy enough.
#4880
looks alot like our track on a practice day.(we water better on race days)
Goose bumps in green compound work the best for us, with losi ifmar pins in red a close second. Shortening your camber links front and rear will help also. We all run very little negitive camber, between 0&-1 degree max.) running 0 degrees anti squat will help the rear end too. I've found personally that with a mod motor I need to dial some expo out also. Some of the younger guys don't seem to need too though. My 2 1/2 cents.
#4887
#4888
Carbon Fiber is stiffer and not as flexible as plastic. So if you guys are breaking them all the time, go to the standard B4 tower, otherwise you'll be breaking your front tower even more.
Paul
#4889
How are you guys breaking them? I have never broken a front tower on my b4? and I've taken my fair share of licks with it.
Paul
Paul
