Like Tree34Likes
RC10B4/T4 Forum
Old 06-20-2008, 09:48 AM
  #4831
chewiefttc4's Avatar
Trader Rating: 26 (96%+)
Originally Posted by AssocRacer View Post
You're WAY undergeared. I run the Novak 10.5 in mine and i'm running 87/25.
thats also with a 10.5 motor.
hes running a 6900 rpm per volt motor equivilent to a 9 turn
theres nothing wrong with his gearing.
also i wouldnt go higher than a 20 tooth on that motor.
the motor is naturally a hot motor.
for racing i couldnt use no where near the power it outputs. and i dropped to a 5700
the 5700 is plenty fast to keep up with a 5.5
chewiefttc4 is offline
Old 06-20-2008, 03:29 PM
  #4832
Scottrik's Avatar
Trader Rating: 261 (100%+)
A question for the assembled T4 / B4 experts here...
I just received two pairs of threaded rear shock bodies and two pairs of threaded front shock bodies I purchased on e-Bay. They are supposed to be "hard coated" and one pair of each certainly is. The other pair of each looks like plain old dull aluminum. Regardless of color they DO have the same part number on the header tags. The header tag on the "plain" looking fronts says "anodized" but the header card on the rears just says "threaded shock" with no reference to anodizing.
The folks I bought from supposedly closed a hobby shop. Their reply was that it was a running change from when production was moved to China, that they are all hard coated.
Is this the case or is someone blowing smoke up my skirt?
Scottrik is offline
Old 06-20-2008, 03:47 PM
  #4833
ben73's Avatar
Trader Rating: 40 (100%+)
there are two different colors floating around. one set I have is a lot lighter than my last two FT cars. all were the FT hard coated shocks though.
ben73 is offline
Old 06-20-2008, 05:02 PM
  #4834
jobo_ph's Avatar
Like Ben73 said, that is the case with the threaded shock bodies from AE. I've read posts on this thread saying the darker ones having better hard anodizing.
Aesthetically speaking, it wound be better if the shock bodies are hard anodized (shaded) the same, but I, personally, can't tell any difference between the lighter and the darker ones in terms of performance and longevity.
jobo_ph is offline
Old 06-20-2008, 05:10 PM
  #4835
Mason's Avatar
Originally Posted by jobo_ph View Post
Things to check:
1. Pinion gear grub screw tightness
2. Slipper tightness
3. Diff tightness
also needs to check axle pin, cvd pin.. basically he/she needs to take their car apart and learn how it works.
Mason is offline
Old 06-20-2008, 07:23 PM
  #4836
i built the car so i have a fair idea on how it works.
i will check all those things today and get bak 2 u all.
whitty is offline
Old 06-20-2008, 08:02 PM
  #4837
while thinking of it. if i take the car off the ground and give it full it powers up all good but as soon as its on the ground it slows down alot.
whitty is offline
Old 06-20-2008, 08:18 PM
  #4838
ffpm46's Avatar
Trader Rating: 175 (99%+)
Default FT T4 converted to J82
I am looking for a like new FT T4 to convert to that J concepts J82.
If anyone is running that J82, what ESC and motor are you using?
Thanks for the help.
ffpm46 is offline
Old 06-20-2008, 09:08 PM
  #4839
well i check all the cvd's, pins ect ect and the tranny and all good. i looked at my wheels and noticed that my wheel where the pin goes into had molded over the metal pin that is on the shaft of the car. so this could have been the reason for this happening. one question i am contemplating going to a 5.5 or 6.5 novak is this goin to continue happenin with that power.
whitty is offline
Old 06-20-2008, 10:50 PM
  #4840
Drifting101's Avatar
I just signed on to ask the same question
Thanks for asking it for me
Drifting101 is offline
Old 06-20-2008, 11:04 PM
  #4841
Trader Rating: 32 (100%+)
Yes, they are all hard coated. The newer shock bodies should be a darker color and I think they have a little more thread on them. But the older shock bodies are also hard coated.
trilerian is offline
Old 06-21-2008, 06:59 AM
  #4842
Scottrik's Avatar
Excellent news. Thanks guys.
Scottrik is offline
Old 06-21-2008, 09:00 AM
  #4843
TfnG's Avatar
Trader Rating: 27 (100%+)
anyone ever have a problem with the t-nut for the T4 differential? the T's are gone from mine...makes it difficult to tighten or loosen the diff.
TfnG is offline
Old 06-21-2008, 11:28 PM
  #4844
Anyone know what gearing to start out with for a B4 with brushless 10.5...
ryno1922 is offline
Old 06-22-2008, 01:22 AM
  #4845
Hey i was wondering what is the best for mod truck (T4) velocity light 4.5, velocity light 5.5, velocity 5.5 or velocity 6.5?
Cheers
