Like Tree34Likes
RC10B4/T4 Forum
Old 06-02-2008, 04:55 PM
  #4681
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Originally Posted by K_King View Post
The B4 turns at it is, hence why most run 30 degrees. Even at high bite tracks they run 30 to make the car less twitchy.
Are you guys running all plastic? Im wondering if that wouldnt help anything.
with my rb5 i found the 30 deg to be more twitchy less predictable.
anyway we are running plastic chassis, the way they come new now. carbon arms towers and hubs.
I would try the set-up. It's really dialed and works at different tracks with minimal changes.
we also ground down the rear bulkhead flat where the ball stud goes. then add shims if it needs to be raised again. i am flat with one shim.... mad dialed and rotates predictably. Cause dialed just isn't enough.... lol
Thanks mertz !
Jason Pelletier is offline
Old 06-02-2008, 05:38 PM
  #4682
K_King's Avatar
Trader Rating: 47 (100%+)
Im going to see if I like all plastic, it should add grip to the car that already has enough steering.
K_King is offline
Old 06-02-2008, 07:36 PM
  #4683
nikos2002's Avatar
Trader Rating: 30 (100%+)
RB Five, you said that set up worked in CT - what tires were you running - same as at LIR???
nikos2002 is offline
Old 06-02-2008, 08:23 PM
  #4684
SQC049's Avatar
Trader Rating: 18 (95%+)
I think he was running J-Concepts double dees on the rear and pink taper fronts. I have heard that people have run the the same tires as lir with pretty good success.
SQC049 is offline
Old 06-02-2008, 08:45 PM
  #4685
Originally Posted by RB FIVE View Post
Oh yeah my bad.... i thought he wrote 35wt.
Correction: thats almost the dialed shock set-up
hahaha thats what i ment!
ktmusa is offline
Old 06-03-2008, 08:28 AM
  #4686
Nice avatar !!
Anyway yea it was fine, me and mertz were both in the a-main first day there. We had switched to green springs in the rear there as it made the car more stable through the washboard like doubles.
i was running JC DD's and rounders, I think that pink taper fronts were better though. If your tight on cash bkbars worked good.
I bet those new blue compound barcodes would be dialed there if they wet the track alittle more.
Old 06-03-2008, 08:55 AM
  #4687
What up?'s Avatar
Trader Rating: 14 (100%+)
Originally Posted by SQC049 View Post
This is the setup I'm running, it was given to me by one of the fastest guys at my local track. It is dialed at our track. (LIR)
Front:
#1 pistons with 35 weight AE shoick oil brown springs.
Inside hole on tower, outside on arm.
2-b camber link(outside on tower, outside on hub). With 2 ballstud washers.
25 degree caster blocks moved forward(stock).
1 washer under ballstud on spindle.
-1 degree camber.
Ride height- Arms Level.
Rear:
#2 pistons with 25 weight AE shock oil green springs.
Inside hole on tower, inside on arm.
1-b camber link(inside on u-brace, middle on hub). With no washers on u-brace.
Running wheelbase in the middle(1 washer on each side of hub).
0 degree anti-squat.
-1 degree camber.
Ride Height- Bones just above level.
Any shock limiters on this set up?
How much weight would you add running Lipo's?
What up? is offline
Old 06-03-2008, 09:00 AM
  #4688
SQC049's Avatar
No limiters. I run a 4.5oz plate under the battery with my Lipos. I also run a 1/2oz of weight in the front and 1 1/2 oz in the rear.
SQC049 is offline
Old 06-03-2008, 09:51 AM
  #4689
Thats too much weight in the front. You should take 1/4 oz out. too much weight makes it push.
Old 06-03-2008, 09:57 AM
  #4690
SQC049's Avatar
Works fine for me. I didn't have a problem out qualifying you on Friday night!
SQC049 is offline
Old 06-03-2008, 10:16 AM
  #4691
and i didn't have a problem beating you in the main or the first 2 qualifiers.....
get your losi and see ya later bye !
Besides see me on normal qualifing circumstances. I will show you the fire.
Old 06-03-2008, 11:23 AM
  #4692
SQC049's Avatar
We'll see.
SQC049 is offline
Old 06-03-2008, 12:13 PM
  #4693
What up?'s Avatar
That seems like 1oz too much from what I have read, Oh well what ever works for you? I'm not a big fan of adding weight but on this car I am going to try it.
What up? is offline
Old 06-03-2008, 12:18 PM
  #4694
SQC049's Avatar
I works fine for me. My car is dialed just the way it is and I do very well with it.
SQC049 is offline
Old 06-03-2008, 12:25 PM
  #4695
Yea his car drives really good. I don't think my car needs 1/2oz but it needs at least 1/4oz wt. on the front.
