Like Tree34Likes
RC10B4/T4 Forum
Old 04-19-2008, 09:05 AM
  #4486
speedsterblade's Avatar
for more durability, I would reccommend Lunsford Ti turnbuckles and may be the hindge pins. The lunsford buckles over the AE FT blues are thicker and stronger. I'm replacing all the AE FT ones on my b44 w/ lunsfords... even the lunsford ones can be bent but they are much stronger than the FT ones.
speedsterblade is offline
Old 04-23-2008, 11:14 AM
  #4487
MOmo's Avatar
I agree with what was said, an aluminum bulkhead CAN be helpful, but a good whack could mess things up. Otherwise, upgraded ti turnbuckles (Lunsford FTW) and really a heatsink motor plate is about all you need.
MOmo
MOmo is offline
Old 04-23-2008, 11:42 AM
  #4488
rifleman223's Avatar
MOmo
I have the FT B4. What aftermarket heatsinks are available? Thanks in advance.
rifleman223 is offline
Old 04-23-2008, 12:21 PM
  #4489
My B4 is almost ready to hit the track. Check it out...
ryno1922 is offline
Old 04-23-2008, 12:24 PM
  #4490
d4man's Avatar
Umm, one problem. That's a B4, not a B44
d4man is offline
Old 04-23-2008, 12:32 PM
  #4491
chewiefttc4's Avatar
Trader Rating: 26 (96%+)
although those washers look cool on the bottom of the rear shocks. take them off. if you break a rear arm youll end up ripping the shock eye in half every time.
been there done that.
chewiefttc4 is offline
Old 04-23-2008, 12:35 PM
  #4492
Woops...I meant to say B4...I just finished a B44 as well that I posted in the B44 forum...
ryno1922 is offline
Old 04-23-2008, 01:35 PM
  #4493
I think he's referencing the FT motor plate that is milled/grooved for more surface area compared to the stock/rtr one. You may have it if you got a FT kit but I'm not sure it comes w/ the ft kit.... Trinity makes or use to make one also. I don't know of any motor heat sinks that would fit/work on a b4/t4.
Old 04-23-2008, 02:48 PM
  #4494
Thanks, that is what I thought. I mistakenly thought that there was an aftermarket plate. Either case, I am sure that the current one is sufficient with the larger surface are than the non FT one.
Old 04-24-2008, 10:49 AM
  #4495
Racers Edge makes (or made) an anodized motor plate as well, it is a little beefier. In any case, I actually prefer the stock plate to the FT blue milled one, as I think it flexes less.
071crazy is offline
Old 04-24-2008, 04:41 PM
  #4496
LOW ET's Avatar
Trader Rating: 106 (100%+)
what type of front/rear tires do you guys recommend for running on VERY low cut grass and dusty hard packed dirt?
has anyone had problems with the the camber link ball studs coming loose out of the shock tower? what did you use to keep them in place?
LOW ET is offline
Old 04-25-2008, 04:05 PM
  #4497
RC Dad's Avatar
Trader Rating: 26 (100%+)
I'd run ifmar studs on the rear - aggressive enough to grab in grass but decent for the hard-pack also. If you're just bashing get silvers - they last a little longer
RC Dad is offline
Old 04-25-2008, 10:47 PM
  #4498
utahrcracer's Avatar
its been about a year I think it is time to dust off the t4
utahrcracer is offline
Old 04-26-2008, 11:55 AM
  #4499
dougyunker's Avatar
LOW ET, are you referring to the front or rear for camber?
dougyunker is offline
Old 04-26-2008, 03:06 PM
  #4500
LOW ET's Avatar
both. my truck is brand new and i ran it maybe four times now and after going over everything i noticed both the front and rear ballstuds for the camber links on the shock towers were backing out of the hole. do you guys use some type of loctite or maybe a longer threaded side so we can put nuts on the other side of the ballstud?
LOW ET is offline
