Like Tree34Likes
RC10B4/T4 Forum
Old 04-07-2008, 06:30 PM
  #4441
Hockey 85's Avatar
Originally Posted by Quinn Konitzer View Post
Thanks. I was wondering because all of my previous vehicles had spacers. One more question. Do you know why my wheel won't keep spinning as long as the other one? I replaced the bearings and backed off the screw, but it still won't spin very easily.
The only things that i can think of would be either a bent axle, a bearing that came packed with a lot of grease, or when you put in the bearing make sure that it is seated in all of the way, you can do this by putting the bearing in the rim, then put it on the car, then the button head screw about half of the way in, pull the tire out against the screw and you will probably hear a lil pop and then screw it all of the way down. My guess is that some of the bearings just come packed with more grease than others. Post when you figure out what it is
Hockey 85 is offline
Old 04-07-2008, 07:55 PM
  #4442
Troy_Konitzer's Avatar
Location: Abrams, WI (Yes the same town as CJ & John Greaves)
I have tried several sets of different bearings and that didn't help. I'm guessing I have a bent axle. Thanks.
Troy_Konitzer is offline
Old 04-07-2008, 07:56 PM
  #4443
Quinn Konitzer's Avatar
Oops. Wrong account.
Quinn Konitzer is offline
Old 04-07-2008, 09:43 PM
  #4444
any suggestions on setting up my t4 for a dirt oval mostly flat not very big?
AJGs10 is offline
Old 04-08-2008, 01:19 PM
  #4445
dougyunker's Avatar
When I ran my T4 on oval I used B4 buggy front and rear shocks and shock towers to lower it as much as possible. I'm not quit sure what front springs I used, but I ran red rear springs. For tires I had on Pro-Line striker II's. Hope this helps.
dougyunker is offline
Old 04-08-2008, 01:31 PM
  #4446
speedsterblade's Avatar
you may also want to try a sway bar for that oval setup... and maybe 1.5 degree racer edge hubs...should help it square up on the power out of the turns.
speedsterblade is offline
Old 04-08-2008, 02:50 PM
  #4447
hey troy, is there the blue factory team front axles on it, if so put the standard steel front axles the blue ones break easy and I guess could also bend easy.
sght4 is offline
Old 04-08-2008, 04:29 PM
  #4448
Thanks Shelly.
Old 04-08-2008, 04:57 PM
  #4449
K_King's Avatar
Trader Rating: 47 (100%+)
Is anyone else using the TC5 shock caps? I got them on my B44 from a guy I bought of Tech and they are soooooooooo much easier to build with.
K_King is offline
Old 04-08-2008, 05:28 PM
  #4450
sportsracer-5's Avatar
What are the benefits of using the TC5 shock caps?
sportsracer-5 is offline
Old 04-08-2008, 05:43 PM
  #4451
K_King's Avatar
Well this is the only time Ive used them. They have a bladder on the top, so no more filling the top up with oil. Basically all I had to do was fill up the shock to ALMOST the very top, push the shaft in, screw the top on. If anything I had to bleed very little of the oil out.
I saved sooooooooo much more time on them its not even funny and they are just as smooth. Im glad the guy had them on it actually.
K_King is offline
Old 04-08-2008, 06:42 PM
  #4452
slammin's Avatar
Trader Rating: 88 (100%+)
Whats the latest and best set up for a ruff track?
slammin is offline
Old 04-08-2008, 10:32 PM
  #4453
Ah right, I see. Yes, shocks with bladders are definitely the way to go, super easy to build. Was it just the top part you bought? Happen to know if AE sells them alone w/o the rest of the shock? I suppose I should just look... anyway, thanks for the tip.
Old 04-08-2008, 10:35 PM
  #4454
K_King's Avatar
It came with my B44, he said theres a kit or something that he changed them with, that cost around 20 bucks.
K_King is offline
Old 04-08-2008, 10:42 PM
  #4455
speedsterblade do you know where to get those hubs? any suggestions on what motor esc, battery setup to run? been thinking about getting the momba max 5700 system and i don't know what battery
AJGs10 is offline
