RC10B4/T4 Forum
#4426
I've really found something in powdered graphite instead of grease or oil to lube the tranny gears. It makes sense when you think about it, drops of liquid lubricants try to stick to each other, and at high speeds can drag on the drivetrain. But a dry lube like powdered graphite just floats around in there.
#4427
Can someone tell me what size the #4 washer is?
http://www.losipartshouse.com/servle...-Washer/Detail
Is it .020"?
Is it .020"?
#4429
Hey guys im new to this thread Just wanted to say i love my b4 im constantly trying to tweak the car to make it better always try new stuff you never know anyway Team associated rock on!!!!!!!!!!
#4430
Hi guys!!
How free do you run your diffs??
When I hold the spur and spin the wheels, it turns 2 or 3 times
Does it sound ok? I dont want the diff to slip, I'm running a Novak 5.5 so..
How does yours feel??
THANKS!!!
THANKS!!!
#4432
Kevin - the #4 washers are .044, or at least that is what my calipers tell me.
Loverc - I would tighten that diff up about 1/16th of a turn, and make sure that you keep your slipper clutch adjusted right so that the diff doesn't slip. You should start with your slipper 2 turns out, from all of the way tightened down.
#4433
Hey, I am new to Team Associated and recently bought a used B4 factory team kit. I was wondering, is there supposed to be a washer/spacer between the two bearings in the front wheels? Please help!
#4434
#4435
Thanks. I was wondering because all of my previous vehicles had spacers. One more question. Do you know why my wheel won't keep spinning as long as the other one? I replaced the bearings and backed off the screw, but it still won't spin very easily.
#4436
If you're running a 5.5, make sure you have some give in the slipper, just like hockey 85 said.
#4437
Oh wow thicker than I thought, I put .030s in there but I have enough time until the next JBRL I go to haha.
#4439
New to the forum. i'm goin to start racing at my local dirt oval in stock class. mostly flat not very big. Just bought a t4. Here are the specs TEAM ASSOCIATED RC10T4 TEAM TRUCK. (IT MIGHT EVEN BE A FACTORY EDITION, NOT REALLY SURE)
TRUCK-
-TEAM ALUMINUM BLUE SHOCKS
-BLUE ALUMINUM THUMB SCREWS
-FACTORY BLUE ALUMINUM MOTOR PLATE
-FACTORY BLUE FRONT PIVOT MOUNT
-RPM BLACK MOTOR COVER
-RPM BLACKSHORT FRONT BUMPER
-RPM BLUE HEAVY DUTY ROD ENDS
-AE CARBON FIBER BATTERY HOLD DOWN
-CVD'S ON REAR (NOT DOGBONE'S LIKE THE RTR VERSION)
ELECTRONICS-
-NOVAK XRS SPORT REVERSIBLE ELECTRONIC SPEED CONTROL
(DEANS PLUGS INSTALLED ON BOTH END'S. FOR BATTERY AND QUICK DISCONNECT TO MOTOR)
-AE 2 CHANNEL RECEIVER AND TRANSMITTER (TR203A)
-TEAM CHECKPOINT MOTOR (I THINK IT'S A 19 TURN)
-HITEC HS-300 STEERING SERVO
does this sound like a decent truck to start with? And if anyone has suggestions on setting this truck up that would be great.
here is a pic of the truck
TRUCK-
ELECTRONICS-
#4440
just check the temp on the esc i never had any luck with those novaks not getting hot and shutting down.
