RC10B4/T4 Forum
#3916
yeah, that's a CV joint. WAY better than standard dogbones
...followed by universal joints
...followed by Traxxas sliders
...and then dogbones.
#3917
Dogbones are used in some conditions as a tuning option(there are no UNI's available for the AE cars). Losi setups use CVD's or UNI's depending on conditions too. CVD's have a cerain amount of bind inherrent in them that makes the suspension level out more under power because of the larger diameter barrel used in the joint. UNI's are more free under power and tend to work better on rough tracks with lower traction. One is not really a better or worse than another.
#3918
Dude, these aren't touring cars. It's not worth tweaking an "inherent bind" in the drivetrain on a truck that's likely to come off the track with the tires caked in dirt and the chassis covered in marbles.
What can make a difference is the notching effect a universal gets at the more extreme angles, and these being offroad trucks the u-joints cut a wide range of movement. That's why I keep seeing those stupid Losi plastic u-joints exploding, at the limits of the suspension the joint gets pounded on by repeated stress and the plastic fatigues. CVs don't do that, which is why they come standard on the higher end kits. RTRs have dogbones just because they're dirt cheap to produce
#3919
dogbone = more side traction , less forward bite, smoother over bumps..
Cvd = less side traction(more corner speed), more forward bite....
Many top driver`s use both depending on track condition`s...
#3921
When I raced stock like forever ago I ran a P2K2 and Monster.
I suppose the CO2 will eventually take the place of the monster
since they both come from trinity.
Unless Trinty decides to make another monster, which is possible.
#3922
Delete this moderator, I had a double post.
#3923
Im guessing you are looking for more rear traction. If you went all plastic arms and all...keep the rear arms plastic and go back to the graphite front arms and you will get some of the traction back. Or you could add another hole further in on the rear shock tower and go that route. I tried the universals but I think I spent more time picking them up off the track then they benefited....
#3924
TRI33011 is the part number for Trinity blue aluminum shock collars......
#3926
Do you run tow-out?
Should I run 1 to 1 1/2 degree toe out to get the entry and as the weight transerfer to the other side I reduce steering?
I was having problems with a sweeper
I would have to break before entry while everyone else just coasted of use less throttle.
Camber is 1 degree all around
tires are the Losi White Tapers (taper on outside, ribbed inside)
Off-road is very new to me and I didn't get a change to experiment before the races last weekend. My off-road expeierence totals 4 heats and the main so i have alot to learn.
#3927
I saw someone mentioned using the JConcepts GT2 body. Obviously the front is the same, how about the back any problems fitting it? I like the fact its .040 and since i am running lipo weight is not going to be a problem.
#3928
I have used dogbones on a B4. It is a rare change to make. They are a similar adjustment to going from CVD's to UNI's on a Losi and has a similar change in feel to removing 1-2* of antisquat.
#3929
Anyone know what lipo would be a direct fit in the t4. Would love to save some weight. Running dirt oval with it and don't know what the legal weight is but the truck is over 60oz. now with 6 cell and brushless motor.
#3930
all of the orion/peak lipos fit great , ray
