Like Tree34Likes
RC10B4/T4 Forum
Old 01-12-2008, 02:02 PM
  #3886
LOW ET's Avatar
Trader Rating: 106 (100%+)
i got three shocks built already with no problems but this one is being a bitch. it's like the shock is over bored, the groove is in the wrong place, the clamp is to small of a diameter, or the total height of the spacers/orings is to tall. it has to be one of those reasons. i guess i'll have to buy a new shock assembly and go from there. since i've been building this kit i have been very disappointed in ae. it was missing some small parts and now this.
LOW ET is offline
Old 01-12-2008, 02:20 PM
  #3887
Registered User
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Damn I miss Losi shocks. The Ae's are more time consuming, but work well.
Dasupacat1 is offline
Old 01-12-2008, 05:42 PM
  #3888
carbon madness's Avatar
Is there an aluminum servo saver, or steering rack for the B4/T4? I only want it as I seem to have a problem with the servo saver striping out when ever it feels like it.
carbon madness is offline
Old 01-12-2008, 05:48 PM
  #3889
air8's Avatar
Yes there is. I don't know the number so you'll have to google it. Or search this thread. I've had the same problem too. Each time I put it together I cinch it down less and less. I've been good for the last couple of months. But it takes a pounding from all the pipes and other trucks I run into. LOL.
air8 is offline
Old 01-12-2008, 06:29 PM
  #3890
Originally Posted by BSchorr View Post
I need a dialed setup that will make my rear end stick to the track and have mad steering for a B4. Running on an indoor high bite clay track running Pink taper slicks.
If previous advices are not enough, check this http://www.petitrc.com/view_news.php?id=4533
The 2005 WC setup seems to be the standard setup / starting point.
Arn0 is offline
Old 01-12-2008, 09:31 PM
  #3891
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 93 (100%+)
Originally Posted by aeRayls View Post
Front, 35wt #1's Browns, shocks middle on tower out on arm.
Camber link 1 washer, inside/inside -1* axle mid 25* blocks
Rear, 30wt #2's Silvers, shocks inside/inside 1 limiter
Camber link 1washer, inside/middle -1* hubs mid
Battery, middle or back.
Add 1.5oz. weight
1 bumpsteer washer on spindle black ballstud on rack.
24.5 mm ride height front and rear
Unscrew front shock eyelet .060 OR use the new .080 shock shaft with 1 limiter inside More durable!
If you make slicks for the front out of tapers they will TURN!Thus the 25* castor blocks. The rear foam is paramount! IF it goes away no setup change will help.
I am running the same setup as that, but with green rear springs as everyone is. The one you mentioned above is the Ryan Cavilieri Trackside 2007 setup. My issue is the rear of the car getting loose in the corners and not very good exit steering. So I am going to go from 2 to 3 degrees of anti-squat to help the car rotate better thru the turns and add 2 shims instead 1 under the ballstud in the U-brace.
Question, what is updated on the "U-braces" I see that it says that on the setip notes.
How do i get more exit steering? Shortening the rear wheel base? Or give it alittle front toe-out to give exit steering like a sedan?
BSchorr is offline
Old 01-13-2008, 08:25 AM
  #3892
Davidka's Avatar
Trader Rating: 85 (100%+)
Try softer rear shock oil. I think-27.5wt is all the heavier you want. With 30wt rebound might be too slow too allow good weight transfer.
Davidka is offline
Old 01-14-2008, 01:13 AM
  #3893
zapmike's Avatar
anyone know where i can get some spoke front wheels for the b4? preferably yellow, thanks in advance!
zapmike is offline
Old 01-14-2008, 01:15 AM
  #3894
BSchorr's Avatar
try JConcepts
BSchorr is offline
Old 01-14-2008, 07:58 AM
  #3895
speedsterblade's Avatar
Or heavier oil? the rear could be transferring weight too fast?? Slamming the weight over, not really controller it? Just a guess... maybe just try a quick spring change to see what it does?
speedsterblade is offline
Old 01-14-2008, 08:03 AM
  #3896
The new u-brace has a little more material where the camber ballstud is mounted. It is just like adding 2 washers to the old brace.
071crazy is offline
Old 01-14-2008, 09:26 AM
  #3897
Mike Marshall's Avatar
Does anybody know if you can buy the set screws only out of the 7381 cvd rebuild package. It seems strange to me that I have to buy a 8 dollar rebuild kit when the only thing I am trying to replace is a set screw that came messed up with the kit. It's like its broken off or something, its only half as long as the good one and no place to put the wrench into it.
Mike Marshall is offline
Old 01-14-2008, 09:39 AM
  #3898
BSchorr's Avatar
You can buy individual set screws, just have to do some hunting, find out the size
BSchorr is offline
Old 01-14-2008, 10:33 AM
  #3899
can you send it back?
I bought a FT alum. thumb screw tc4 kit for the battery strap long ago..one was threaded, one was NOT! It was sent back and I was credited.
Old 01-14-2008, 12:06 PM
  #3900
VPRTRL's Avatar
Try True Value Hardware stores, the genneraly have an exccellent assortment of both metric and english hardware. I purchase all of my screws there for both my X-RAY T2007 and my T4.
VPRTRL is offline
