RC10B4/T4 Forum
#3841
Broke an A arm today on mhy T4 and I remember reading i believe that RPM GT2 A arms fit the T4, am I correct? This is the part that I was planning to order. http://www3.towerhobbies.com/cgi-bin...?&I=LXRFW1&P=7
Will this work?
Will this work?
#3842
I also read that you have to use GT2 front hinge pins also, has anyone done this on thier T4 or have any info?
#3844
I will answer my own question after I did some reasearch on RC10T4...the front arm work if you buy the set that includes the bulkhead, then you also need the front hinge-pins which only come as a front/backk set as far as I know. RPM has lifetime garauntee on thier parts..yea. This should do the trick.
#3845
opps i was typing as you posted...lol
#3846
Yea i already have the blue aluminum one....kinda sucks. You can have enough anodized parts.
#3847
#3848
I converted my t4 front end to a gt2 front end. I think it turns better and have not broke a single arm since the switch. I've also gone to 30 degree caster blocks and it turns on a dime. I used the gt2 arms, hinge pins, caster blocks and steering blocks...Carolinas RC had everything i needed.
#3850
hey JROCK i would love some better steering could you get me the part numbers for the steering blocks and castor blocks....are the steering blocks necessary or just the castor blocks, im getting ready to put in the order for the A rms and hinge pin set..this would finish off the order nicely. Thanks
#3851
Hey I dug out my Video camera and the necessary cables so when I get these A arms in I will post the beast on 2's and 3's Lipo...does anyone know of an easy free program for video editing... I just want to a front page and some trimming, then Ill post it on you tube and set up a link. LMK
#3853
#3855
Thanks for the info Syber
