Like Tree34Likes
RC10B4/T4 Forum
Old 11-12-2007, 11:58 AM
  #3226
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
thats alot of weight. why are you guys putting so much in. My buggy has 1/4 oz. under front wheels and the truck has 1/2 oz. in the back.
Jason Pelletier is offline
Old 11-12-2007, 12:06 PM
  #3227
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
That is the standard setup... every team driver has been doing that for atleast 2 years....
Frank Root is offline
Old 11-12-2007, 12:12 PM
  #3228
Tech Legend
Wild Cherry's Avatar
Default For T-4 & B-4 , and even RB-5
Unless you are trying to get less steering, take off that weight on the ft end and try the Team set-up`s...
Wild Cherry is offline
Old 11-12-2007, 01:27 PM
  #3229
Jake S's Avatar
Trader Rating: 67 (93%+)
i run 1 oz between the transmission, and 1/4 oz in each of the pockets in the rear of the chassis. this is with still running brushless, with 4200s.
t4/b4 parts forsale on ebay, search username: mobrcracing
Jake S is offline
Old 11-12-2007, 04:02 PM
  #3230
No, that gives me more steering in my buggy.
Old 11-12-2007, 04:05 PM
  #3231
why ?
Old 11-12-2007, 04:20 PM
  #3232
TLRacing
Frank Root's Avatar
why ?
More weight in the rear, means more weight transfer to the front... and more weight over the rear tires for more forward bite. This is a plus-plus.
Old 11-12-2007, 06:04 PM
  #3233
Tech Legend
You have a lot to learn...
First , next time at the track use some extra weight on the ft , and feel ....
This is a great way for you to understand....
Use weight on the ft end under high traction condition`s....
Like , slicks or blue groove conditions....
It helps keep the nose down when punch out of the corner...(wheelie`s)
also
help`s smooth the steering because you have a whole lot of steering under those condition`s...
however ...
sometimes , when the track is extreme low traction, it also helps smooth the steering there as well....
I`m not trying to be a expert or say don`t use weight on the ft !
Rather wish to share with you why and when ....
Old 11-13-2007, 12:05 AM
  #3234
JeromeB's Avatar
Trader Rating: 26 (100%+)
Hi Im having trouble building the diff in my B4. Ive tightened up all the way in, then backed off 1/8 turn, and it feels lumpy...Is this how its meant to be, I cant remember from when I built the last one.
Thanks in advance.
Jerome
JeromeB is offline
Old 11-13-2007, 01:02 AM
  #3235
K_King's Avatar
Trader Rating: 47 (100%+)
Thanks in advance.
Jerome
No it should be 100% smoooooooooooooth as buttah. I would recommend just buying the diff rebuild kit and some new carbide balls and start fresh.
K_King is offline
Old 11-13-2007, 06:51 AM
  #3236
wog....supraman's Avatar
mmmm.......so thats wats wrong!!!
i betta get around 2 replacing then:P
wog....supraman is offline
Old 11-13-2007, 09:49 AM
  #3237
also
however ...
the rb5 has the 1/4oz. weight in the front i guess i could take it out again and try it but i remeber when i put it there i got more steering ?? i dunno.
I will try more weight in the rear of the truck too and see how it is.
Old 11-13-2007, 10:04 AM
  #3238
george does not run an rb5. take his advice with a grain of salt as it pertains to your buggy. it might still be right, but he is speaking from a b4 perspective.
as for the t4. I run 1 oz in front of my tranny, 1/4 oz in the back slots of chassis, or another 1/2 oz total.. that is before I worry about making minimum weight.
Sweet Lou is offline
Old 11-13-2007, 10:42 AM
  #3239
air8's Avatar
Wait...there is a minimum weight rule? What is the minimum weight for 1/10 electric truck?
Thanx
air8 is offline
Old 11-13-2007, 11:25 AM
  #3240
Thanx
60oz is minimum weight for truck
52oz for buggy
56oz for 4wd
