Like Tree34Likes
RC10B4/T4 Forum
Old 11-08-2007, 05:55 AM
  #3181
t4mania's Avatar
Thanks much CCRISTO!
t4mania is offline
Old 11-08-2007, 06:22 AM
  #3182
wog....supraman's Avatar
Originally Posted by trashedmaxx View Post
Unless your a real pipe hunger the stock team axles can't be beat. I have broke way to many of the FT team blue ones. For the screw you could just cut a notch in with a dremel and use a flat head to get the screw out. Then you will be able to save your wheel.
The splines in the wheel that you are referring to are the old style rims. No different bearing is needed everything will bolt up just fine.
All of the bearings are the same between the B4 and T4.
ahhh yea..i 4got bout the dremel trick...that mate, thanxs 4 the help
cheers
wog
wog....supraman is offline
Old 11-08-2007, 09:05 AM
  #3183
speedsterblade's Avatar
cheers
wog
Works on the racer edge Alum hubs & ballstuds also.
speedsterblade is offline
Old 11-08-2007, 09:10 AM
  #3184
Originally Posted by t4mania View Post
Does anyone make a set of 1.5 degree rear hub carriers for the T4. Racers Edge used to but doesn't anymore.
RE don't???? I know they were making a killing 25-30$ a pair. They work but pricey.... check ebay. T4/b4 RE hubs are the same.
Old 11-08-2007, 09:57 AM
  #3185
PTP Racing's Avatar
I am getting a B4 and Novak 5.5 brushless set-up to run indoors this winter. I have been racing 8th buggies for the past 4 years exclusively. The track is 80x50ft smooth high bite clay. He converts it from oval to offroad. The hot tire set-up is slicks with firm inserts. I am looking for a good starting point for the set-up.
PTP Racing is offline
Old 11-08-2007, 10:19 AM
  #3186
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
First off, I would highly suggest a 7.5 Motor. If you already have the 5.5, or are determined to run it... try 5 cells geared about 23/81.
As for setup,
Front - 35wt., brown springs, #1 piston, -.060" limiting (unscrewed 2 turns), shocks mounted middle tower, outside arm, camber link 1-A with 1 washer, 30* castor blocks, spindles middle, 2 spindle washers, super glue the servo saver together, -1* camber, 0* toe
Rear - 30wt., Silver springs, #2 piston, .030" limiting, shocks inside-inside, camber link 1-b w/1 washer, hubs middle, 2* anti-squat, -1* camber
Don't forget the basics, batter forward or middle (cut the battery pad in 1/2), and adding the 1 1/2 oz. of weight in the rear (1 oz under u-brace in front of tranny, and 1/4 oz. in each rear triangle). Also, the JConcepts 6" HD or V wings are the best in the business. You could run those with no extra lip.
Hope that helps...
Frank Root is offline
Old 11-08-2007, 10:46 AM
  #3187
t4mania's Avatar
Thanks speedsterblade, Racers Edge doesn't make the 1.5* anymore but I found a set at rcplanet.com. They are pricey 25.00!
t4mania is offline
Old 11-08-2007, 10:54 AM
  #3188
PTP Racing's Avatar
Ive already got the 5.5 it said on their website high traction offroad. Is that really going to be too much? I already opened it so I cant return it now. I can limit it cant I? I could get a different motor. At first I grabbed the 4.5 but after reading the website I returned it and got the 5.5.
The track is really high bite my gas truck would sometimes wheely down the straight. I'm used to driving my 1/8th buggy on the track. I see some of the faster 2wd mod guys sometimes catching wheelys but they seem to be able to control it somehow. I havent run 2wd since gas truck and that was a couple years back before they let us run our 1/8th buggies.
Old 11-08-2007, 10:59 AM
  #3189
PTP Racing's Avatar
I have been one of the faster racers in my class at this track in previous years. Just so you know I'm not a newb racer just new to brushless and 2wd mod. Last time I raced 2wd it was stock with a JRX-2. But I do need some advice to get me started. The trinity tech talk site I usually talk to the local racers is currently down so I cant ask my locals.
Old 11-08-2007, 11:50 AM
  #3190
Davidka's Avatar
Trader Rating: 85 (100%+)
The 5.5 is a little too much but you can turn down your epa and exp to tune/limit the power. It would also work nicely with a 5 cell if you're running conventional batteries.
Davidka is offline
Old 11-08-2007, 12:43 PM
  #3191
PTP Racing's Avatar
I'm a big fan of exponential. I dont understand why everyone doesnt use it.
On my 1/8th buggy I bought a 3 port last winter to run in there and hated it. It wasnt near as fast as my other engines. Even though the track was small I still didnt like being down on power.
I dont have any batteries yet but plan to use nimh.
Old 11-08-2007, 12:46 PM
  #3192
I ran a 5.5 in my t4 at our newly redun indoor (100' straight)...5.5 was way too much for my track. 6.5 better but I still have to dail it down some on the radio. I can't image the 5.5 in my buggy. I ran a 6.5 on a big outdoor track in the buggy and it was about perfect. Some guys at my track are running the gearing a touch higher to help w/ the wheel spin, just keep an eye on the temps...
Old 11-08-2007, 01:18 PM
  #3193
You guys that want to soften up the 5.5 motor, use the throttle expo in your radio if it has that. We use as much as negative 100% depending on the track condition. It sure helps soften up the wheel spin off the corners on a slick track.
The easiest way is to go less motor like around a 7.5 if the track gets slick. Less motor will always extend those runtimes too!
Craps is offline
Old 11-08-2007, 04:14 PM
  #3194
Jake S's Avatar
Trader Rating: 67 (93%+)
thing with the 5.5 when it says high traction, i believe it means 4wd offroad.
suggested motors (with sintered rotors) buggy 7.5, truck 6.5.
Jake S is offline
Old 11-08-2007, 05:33 PM
  #3195
mfishel's Avatar
You could have gotten the GT2 hubs. But after buying the bearings it probably wouldn't have saved much.
mfishel is offline
