Like Tree34Likes
RC10B4/T4 Forum
Old 11-02-2007, 11:34 AM
  #3151
RedBull_81's Avatar
Originally Posted by tripthreat View Post
What tires and foam do you run, front/rear?
Any slicks are spec at our track, but we all run these http://www3.towerhobbies.com/cgi-bin...&I=LXNPS9&P=ML.
Turn buckles in front are inside on front shocktower & all the way inside on caster block, & the rear is, in on chassi & middle on rear hubs.
& yes i'm running the extra weight.
RedBull_81 is offline
Old 11-02-2007, 01:20 PM
  #3152
Jake S's Avatar
Trader Rating: 67 (93%+)
if your trying to get more low speed steering, trying shortening the camber link (inside/inside on the front)
Jake S is offline
Old 11-02-2007, 01:41 PM
  #3153
RedBull_81's Avatar
They are like that, sry if I worded that wierd.
Old 11-02-2007, 02:33 PM
  #3154
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
What foams are you running? front? rear? 30* castor blocks?
Frank Root is offline
Old 11-03-2007, 06:29 AM
  #3155
RedBull_81's Avatar
what ever foams come with those tires I posted a link 2 & I run 25* c-hubs
Old 11-03-2007, 10:42 AM
  #3156
TLRacing
Frank Root's Avatar
I would highly suggest 30* castor blocks, they will make the car less twitchy and increase mid-corner steering, we all run them 100* of the time.
Old 11-03-2007, 01:36 PM
  #3157
Trader Rating: 27 (100%+)
hi frank
what kind bushless you are running on your t4 truck
what part number it ? do you have a setup bushless truck ?
i just wonder that speed control with motor??
thank tommy
taztal3 is offline
Old 11-04-2007, 08:29 AM
  #3158
diesel's Avatar
Default Mamba Max 5700 on B4
Hi there,
May I know what pinion gear to use with the stock spur gear on the B4 when using the Mamba Max 5700 system? Any recommended settings for the ESC? Any thermal cut issues so far with this brushless system?
Thanks.
diesel is offline
Old 11-04-2007, 01:25 PM
  #3159
TLRacing
Frank Root's Avatar
Originally Posted by taztal3 View Post
hi frank
thank tommy
In all my cars, I run the Novak GTB and Orion Vortex Motors. For Truck, I am running a 6.5 Orion Vortex, geared 19/87. It is pretty fast.
Frank
Old 11-04-2007, 02:50 PM
  #3160
Jake S's Avatar
Frank
ill be running novak gtb and novak motors (sintered). this summer i mostly ran 7.5 geared 87/20, but on big tracks i felt almost lost against 6.5s....im looking at 87/18 with the novak 6.5 (sintered) the 7.5 will be dropped into the b4 and have an 81/22 gearing.
Jake S is offline
Old 11-04-2007, 03:33 PM
  #3161
You run these front and back on the T4s?
Lextek is offline
Old 11-04-2007, 06:49 PM
  #3162
RedBull_81's Avatar
yep, all the way around.
Old 11-04-2007, 06:51 PM
  #3163
hi frank
what part number a novak gtb ?
what about lrp bushless ?
taztal3 is offline
Old 11-04-2007, 09:25 PM
  #3164
K_King's Avatar
Trader Rating: 47 (100%+)
I wish there was a gearing sticky for these cars, because here goes.
Pinion for Stock in a B4 and T4
Pinion for 19T in a B4 and T4
Thanks in advance
K_King is offline
Old 11-05-2007, 12:39 AM
  #3165
Jake S's Avatar
Thanks in advance
stock in the t4 i have ran between 18-20 with the 87 spur. (87/18 with co27 on most tracks - but i do have one co27 with gobs of torque that will pull 87/20 in 5 minutes and pull off at 150-ish)
stock in the b4 i have ran between 22-24 with the 81 spur (81/22 with co27 on most tracks)
sorry i don't run 19t anywhere.
Jake S is offline
