Like Tree34Likes
RC10B4/T4 Forum
Old 10-29-2007, 10:26 AM
  #3121
Jake S's Avatar
Trader Rating: 67 (93%+)
Originally Posted by RedBull_81 View Post
wow Jake, you have no idea how close our B4 setups are. How do you get the setup sheet so you can use it on the internet? I will post mine
blanks are on ae's website (you must have adobe acrobat to save edited pdfs)
http://rc10.com/racerhub/setup/B4_blank_input.pdf
http://rc10.com/racerhub/setup/T4_blank_input.pdf
Originally Posted by tripthreat View Post
Even if 2's with 40 'feels' like 3's with 35, it will be different on the track. A different piston will give the stock a different pack. 3's have smaller holes than 2's and will have MORE pack. It will make the front end feel more progressive.
im running #2 with ae 35 now. (had to use a conversion table somone had) i have been running the #2 in the front all summer with 30 wt ae, and the truck drove pretty good. but seeing that most pros are running 35wt with the #3 piston, i almost want to get a pair of #3 pistons and try it like that.
Jake S is offline
Old 10-29-2007, 02:14 PM
  #3122
Trader Rating: 23 (100%+)
Default B4
I do run 12 turn mods in my b4.
Jmnay_83 is offline
Old 10-29-2007, 02:42 PM
  #3123
Jake S's Avatar
ok well when you say "all mods" it means other motors then 12 turns.
Jake S is offline
Old 10-31-2007, 11:15 AM
  #3124
RedBull_81's Avatar
hey guys, in my T4's front shocks the kit says to use the #2 pistons, I was wondering what difference I would notice by using the #3 instead??
RedBull_81 is offline
Old 10-31-2007, 11:17 AM
  #3125
OTE_TheMissile's Avatar
#3's are a bit "stiffer", the holes are smaller.
...I think. Never was good at shock tuning.
OTE_TheMissile is offline
Old 10-31-2007, 11:32 AM
  #3126
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Hope that makes sense
Frank Root is offline
Old 10-31-2007, 01:12 PM
  #3127
Trader Rating: 15 (100%+)
Default On/Off power push on T4
I need some help from you guys... My T4 is experiencing some off & on-power push. I am using a lipo and running the "Factory Team" (A.K.A. Ryan Cavalieri) set-up. I put about 1 oz. of lead up front and 3 oz. in the rear. I noticed the rear is hooking up way better now, but the front still doesn't feel "right" compared to another racer's out of the box T4 RS with NiMH. What else could I do to fix this? I've tried many different front tires and there seems to be no solution.
James Y is offline
Old 10-31-2007, 02:08 PM
  #3128
K_King's Avatar
Trader Rating: 47 (100%+)
Why so much weight?
K_King is offline
Old 10-31-2007, 02:18 PM
  #3129
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Its probably a pig cause of all that weight you have in the rear. did you play with the washers under the ball stud on the front bulkhead ?
That setup isnt for a lipo pack with 3 ounces of weight put in the rear too.
Jason Pelletier is offline
Old 10-31-2007, 02:23 PM
  #3130
TLRacing
Frank Root's Avatar
I would just put the standard 1.5 oz in the rear, and none in the front. Then put in the LIPO pack with 1 pad in front, 2 in the rear. Also, add lead to match the difference between a LIPO and NiMH on top of the battery bar right above where the battery lies.
Old 10-31-2007, 02:26 PM
  #3131
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Hey Frank are u still running ur B4 anymore. Or r u just doing on-road again.
BuggyKing is offline
Old 10-31-2007, 02:47 PM
  #3132
TLRacing
Frank Root's Avatar
Yeah, I ran TC last weekend, but off-road the weekend before at Hot Rod.
Each weekend, I just search out races, or run what I am in the mood for.
Old 10-31-2007, 02:53 PM
  #3133
BuggyKing's Avatar
oh ok Frank. I think my bearing in my 7.5 went south.
Old 10-31-2007, 02:54 PM
  #3134
TLRacing
Frank Root's Avatar
That's a bummer
Old 10-31-2007, 11:33 PM
  #3135
Originally Posted by air8 View Post
In my T4 with the 13.5ss pro i'm using 24 or 25 pinion and 87 spur. I have tried several different setup. I was even using a 81 spur for a few weeks. But I consider my self new, only been racing one year.
Using an 87t spur I went down to like a 20 & up from there but found that I could only get to a 24 or 25 b4 running out of adjustment for endplay between pinion & spur. I had an 81t and wound up with a 26/81 combo that works fantastic at our track. Stock buggy times ( with me at the controls) are a best 24. and change for a lap and I ran a 25 second lap in the T4 tonite. Same motor (GTB 13.5) Hope that helps, for w/e its worth.
L8r
Slo-poke
RC10B4 AL is offline
