Like Tree34Likes
RC10B4/T4 Forum
Old 10-27-2007, 11:08 AM
  #3106
FOXY923's Avatar
Originally Posted by gene465 View Post
Just picked up a new B4, want to know what you are all running for a pinion on them. Started with a 24 and now down to a 21T pinion and its a bit hot with stock spur. Have a CO27 motor in it. Seemed like it went faster when I had the Monster stock with a 23T in it. Any recommendations? Thanks Gene
I'd like to know what gearing to start with for the Co27 as well. I'm using the 81 spur and thought I'd start with a 23 pinion. Advise please & thanks.
FOXY923 is offline
Old 10-27-2007, 11:16 AM
  #3107
BuggyKing's Avatar
Trader Rating: 17 (100%+)
I would start with a 19 or 20 pinion. Start with 19 then go from there. That should be fine for an 81 spur.
BuggyKing is offline
Old 10-27-2007, 12:41 PM
  #3108
FOXY923's Avatar
I have a 19 but I'd better get a 18-21. Thanks
FOXY923 is offline
Old 10-27-2007, 12:45 PM
  #3109
Trader Rating: 23 (100%+)
Default B4
I run 21-81 on all stock and mod motors. It is perfect on both.
Jmnay_83 is offline
Old 10-27-2007, 02:02 PM
  #3110
Jake S's Avatar
Trader Rating: 67 (93%+)
bad suggestion....unless your mods you are running at 12 turn mods...which then 81/21 is the suggested gearing....if you run a 11 turn 21 would be overgeared, and you would see high heat. on a 13 turn its safe, but still 81/22 is better for a 13 turn.
Jake S is offline
Old 10-27-2007, 02:03 PM
  #3111
Jake S's Avatar
just went through my shocks to check which pistons i had in, and i was surprised.....in the b4 i have a #1 in the front #2 in the rear, in the t4 i have a #2 in the front and a #1 in the rear....so now i guess i want to adjust my shock oils lol.... usually everyone runs a #3 piston in the front of the t4 with 35 wt oil, so i think a #2 with 40wt should be good, is my thinking right?
posted are my setups (finally got acrobat to edit a blank one and save it)
File Type: pdf
File Type: pdf
Jake S is offline
Old 10-27-2007, 06:13 PM
  #3112
mike.k's Avatar
I would try a 22-24
mike.k is offline
Old 10-27-2007, 06:23 PM
  #3113
Jake S's Avatar
Originally Posted by mike.k View Post
I would try a 22-24
almost exactly what i was saying....start at 81/21 to 81/23
Jake S is offline
Old 10-27-2007, 08:29 PM
  #3114
FOXY923's Avatar
I'll start with a 22 and go from there. Thanks
FOXY923 is offline
Old 10-28-2007, 03:58 PM
  #3115
VR2L_DUDE's Avatar
Default Traxxas VXL-3s
Has anyone tried using the Traxxas VXL-3s and Novak Brushless motor with their B4? Does the VXL-3s fit inside the buggy?
VR2L_DUDE is offline
Old 10-29-2007, 01:39 AM
  #3116
Jake S's Avatar
edited my pdfs, i had to do an oil conversion to AE weights.
Jake S is offline
Old 10-29-2007, 07:43 AM
  #3117
RedBull_81's Avatar
wow Jake, you have no idea how close our B4 setups are. How do you get the setup sheet so you can use it on the internet? I will post mine
RedBull_81 is offline
  #3118
RedBull_81's Avatar
Last edited by RedBull_81; 10-29-2007 at 07:44 AM. Reason: no Idea why it made 2 posts
Old 10-29-2007, 08:42 AM
  #3119
speedsterblade's Avatar
Originally Posted by K_King View Post
Do you guys run plastic rear arms on the T4 as well? I put the GT2 front end on, but I need the hinge pin for the hub carrier as the T4 one is too long.
You can grid it down...or if you have a tc3/tc4 hinge pin kit or spares they fit perfectly. I had spare tc4 pins....
oh, yes I'm running gt2 front end w/ plastic arms on the rear...
speedsterblade is offline
Old 10-29-2007, 10:59 AM
  #3120
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Even if 2's with 40 'feels' like 3's with 35, it will be different on the track. A different piston will give the stock a different pack. 3's have smaller holes than 2's and will have MORE pack. It will make the front end feel more progressive.
Hope that makes sense
Frank Root is offline
