Like Tree34Likes
RC10B4/T4 Forum
Old 10-22-2007, 08:21 PM
  #3046
air8's Avatar
I don't. But I can measure when I get home tonight. I'm curious as well.
air8 is offline
Old 10-23-2007, 03:48 AM
  #3047
The other nut driver size you're looking for is 11/32 for the rear wheels and the servo saver nut
adam lancia is offline
Old 10-23-2007, 05:57 AM
  #3048
MannEdge's Avatar
Trader Rating: 19 (100%+)
Do people seem to have trouble with the stock shock cap on the B4/T4? I am putting my kit together (T4) and those shock caps are junk.
MannEdge is offline
Old 10-23-2007, 06:27 AM
  #3049
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Umm yea i had that issue last night building mine. they nevr wanna thread nicely. i got them to work after a bit of frustration.
Jason Pelletier is offline
Old 10-23-2007, 06:35 AM
  #3050
MannEdge's Avatar
I just purchased the upgrade ones.
MannEdge is offline
Old 10-23-2007, 06:47 AM
  #3051
I bought the yokomo ones but they sucked worse then the stock ones so i opted not to use them
Old 10-23-2007, 10:27 AM
  #3052
d4man's Avatar
Really? I have no problems with my Yokomo Caps. I have them on my B4, T4 and GT2.
d4man is offline
Old 10-23-2007, 10:30 AM
  #3053
BuggyKing's Avatar
Trader Rating: 17 (100%+)
the Yok caps r ok. I didnt care for the small screw though.
BuggyKing is offline
Old 10-23-2007, 10:34 AM
  #3054
Tech Legend
Wild Cherry's Avatar
Default Hummmm
I like my shock caps ....
Wild Cherry is offline
Old 10-23-2007, 11:00 AM
  #3055
Yea i mean i still have them maybe ill try them another day and they will work better. lol
Old 10-23-2007, 11:47 AM
  #3056
air8's Avatar
Originally Posted by Davidka View Post
Does anyone know the diameter of the B4/T4 shock pistons are?
OK. The shock pistons come out to 10.12mm and the inner diameter of the shock body is 10.14mm. Or this could be .398" for piston and .402" for shock body. This is all close to 25/64" if you'd like that measure.
air8 is offline
Old 10-23-2007, 11:49 AM
  #3057
air8's Avatar
Shock Caps. The only issue I had was putting the wrong O-ring on. What problems are there with the stock plastic shock caps?
air8 is offline
Old 10-23-2007, 11:56 AM
  #3058
mfishel's Avatar
Sometimes they are fiddly to get started. When you first install them you need to 'back thread' them a little before starting them. Place them on the body and slowly rotate them in reverse direction until you feel them 'pop' into the thread. Then just begin threading them down. Do this every time and you will be fine.
What upgrade caps are you referring to? I know of none other than the aluminum ones, and they aren't an upgrade.
mfishel is offline
Old 10-23-2007, 12:19 PM
  #3059
air8's Avatar
I have thought about getting the aluminum caps cause they use a taller mount. The plastic caps are short and I have to keep the shock retaining nut loose or else it will bind on the shock cap. But it's not a big issue. just something to watch out for.
air8 is offline
Old 10-23-2007, 01:04 PM
  #3060
speedsterblade's Avatar
I had a small prob with a set of yoks. they didn't thread easily all the way and leaked til I got them truely seated/tightened..... getting them started is a touch harder than the stock ones but not much. I'm still tweaking my bleeding skills but get the job done....
speedsterblade is offline
