RC10B4/T4 Forum
#2641
Take the car off the track and touch the motor
If it's cool, add teeth to the pinion
If you burn yourself, take teeth off the pinion
If it's warm, you're good
Best way to do anything is to just try it, IMO.
#2646
Maybe I'm an idiot also. I've tried to find certain posts several times and have had no luck. Whatever key words I enter turn up nothing.
#2647
Is there any parts that swap between the GT2 and the T4? When I wrecked my GT2 last weekend it seemed like the T4 parts were different enough to not work right. I kind of thought some parts between the two were interchangeable. It really looks like none are the same.
#2649
Ryan Maifield uses the GT2 front end on his T4. The parts he uses are, the GT2 a-arms, caster blocks, hinge pins, steering arm and trailing axles.
#2650
join em.
CR is gone, hello B4.
sure loox nicer, was thrown by no front body mount however.
look forward to runnin it soon. any1 have p#s for servo horns and ballstud for that horn (were removed by previous owner). thank you.
fittin my 4th rc10 in 20yrs is in fact a b4, 1st in 15yrs
R
R
#2651
Ballstud is AE part #3858 I believe you want a short stud there and with the stud threaded so the ball points towards the back of the car
You might also need a #7336 Servo Mount & Spacer kit if the previous owner didn't include those either
#2652
There actually is a front mount, atop the right side of servo saver...but most people just like to use velcro to mount the body anyways.
Also, what servo are you going to be using? If it's a JR590M, the JR servo horn included in the AE servo horn tree isn't going to work.
#2653
i could use another 590, but i'm kinda gettin talked into a hobbico digital. lil easier on the wallet and i should go digital. just had put it off w/the other car.
the servo mounts are there, just noticed this spacer issue however. idk what setup hobbico servos are (hitec?). just cant drop for an AR digital for time being.
thank u all for the info.
R
R
#2654
To add to this question--I've been caught not being able to mount up servos several times cause I don't have the correct screw or washer under the screw. So, I have been trying to decide what is needed to mount up all brands. JR, Air, Ace, Futaba, Hitec, KO, Sanwa, Bluebird...uh..can't think of any others. My point--the horn mounting screws are different for some output shafts. Metric or standard/course thread or fine thread. Little things. It's just little things. I get P.O.'d about this issue too much cause I can't seem to get it figured out. Oh and cap head or flat head. Some use awesome aluminum washers under the flat heads. I like that. But mostly I just want to get the frikkin servo horn mounted to the frikkin servo so I can drive my frikkin cars. (Austin Powers montage) lol
#2655
1st go round. no time for setup on it, just throw in my electrics and go on what the previous owner had. i can say even under those conditions i was very comfortable w/the car and fact that it turns. somethin the CR couldnt do consistantly at all with the ever changing conditions to both car, surface, and track preparation.
i do need to do a complete teardown and freshen up the car to my liking. but agian, i'm very pleased. has me thinkin of settin it up for dirt oval for winter. heh
R
R
