Like Tree34Likes
RC10B4/T4 Forum
Old 08-29-2007, 12:57 PM
  #2626
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Originally Posted by OTE_TheMissile View Post
All depends on the track size, exactly what kind of motor you're using, your driving style, your battery...the only way to find out is to ask around in person at the track what people are running and work from there.
Whats the biggest range. I found a really good deal on some new 48 pitch pinions.
Motor CO 27 for stock and 12X2 Mod
Batt. 4200
Brushless 13.5 to 7.5
Track ??? It's a State Series so there will be 8 different tracks.
RED-LINE M03 is offline
Old 08-29-2007, 01:22 PM
  #2627
POUNDITRACING's Avatar
there are pack of odd and even. I would get anything from 14-24. This will cover any offroad car and any motor choice.
POUNDITRACING is offline
Old 08-29-2007, 01:23 PM
  #2628
Batt. 4200
what car is this for?
Old 08-29-2007, 01:26 PM
  #2629
Tubaboy's Avatar
I'd snag pinions ranging from 17 to 24 for the motors you listed.
CO27 tends to be happy between 19 and 21.
12x2 (I run epic shock) seems to be happy at 20 to 22.
Brushless... Again, depends on the track. One racer put a 24 into his 10.5 once and found his sweet spot for the track. 2 weeks later on a redesigned track the pinion was completely wrong, because it went from a long 100' straight to a 40' straight. So you really have to take into consideration the track you're running on.
If you go to a tight layout, with well packed dirt, a 17 will give you the torque to jump out of the corners (but you'll be slow on any straight longer then 40 feet). Meanwhile, a loose track, you may want to put in a higher pinion to reduce wheelspin, less torque but get higher speed on the straight. Really it just takes practice and tuning.
Paul
Batt. 4200
Tubaboy is offline
Old 08-29-2007, 03:16 PM
  #2630
Jake S's Avatar
Trader Rating: 67 (93%+)
i have a 12 turn in my t4 im running 19-20 with an 87 spur.
13 turn in my b4, running 23-24 with an 81 spur.
these are with orion v2 mods...soon switching to fantom cp based mods (11 turn and 13 turn)
Jake S is offline
Old 08-29-2007, 03:19 PM
  #2631
The truck should be 7 over the wind
The buggy should be 9 over the wind.
That's what Joe Pillers says.
Old 08-29-2007, 03:27 PM
  #2632
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Batt. 4200
I can't see anything out of the 19-24 range. These 6 should cover you in all circumstances.
Frank Root is offline
Old 08-29-2007, 10:53 PM
  #2633
Jake S's Avatar
dunno cav said 8 over for the truck, and 9 over for the buggy.....but i liked 81/23 on the buggy with a 13 turn....i have ran the 22 pinion, but it didn't seem like it added any more punch, and i could see a top speed difference....and the 23 on the buggy only added an extra 4-deg over the 22 pinon.
its all a matter of the driver tho....and the track too.
Jake S is offline
Old 08-30-2007, 11:11 AM
  #2634
Hello,
I am new to electric racing and am receiving a brushless motor combo in a trade and wondered how it would do in a B4 in the mod class.
Lrp Sphere competition speed control
Neo1 4 star brushless motor
Neo1 1 start brushless motor
I am not new to the hobby I come to electric with quite a bit of 1/8th scale background. If either of these motors will work well in the B4 running mod and lipo (supported at my track) or NImH what would be the right pinion to go with? I know this is dependent on the track and batteries but how about a ballpark. Thanks in advance.
Josh37 is offline
Old 08-31-2007, 12:35 AM
  #2635
Jake S's Avatar
went racing today, i can say that 20/87 with a 12 turn in the truck runs great. 22/81 with a 13 turn in the buggy is what i liked best on the same track.
Jake S is offline
Old 08-31-2007, 03:08 AM
  #2636
Z-Fire's Avatar
Originally Posted by Josh37 View Post
Hello,
The 1star is a 8.5 = to a 13 brushed good for mod racing I would try 17 on a small track & 20 for large.
Your 4star is a 5.5 = to a 7 turn try 14-18 this one has alot of power good for bashin.
I have a Neo1 3star(6.5) with a 15 tooth in my T4.
Z-Fire is offline
Old 08-31-2007, 08:53 AM
  #2637
Default Gearing question
I know the answer is probably buried in this thread somewhere but I just dont have thetime to read it all...
Just bought a new T4 and all I have for a motor and esc is the Mamba max 7700. I run a 2 cell 3200 lipo. I run on a small indoor track and a medium outdoor track. What do you experienced guys recommend for a pinion with the stock spur?
Thanks for the help.
TEAM-JCJ is offline
Old 08-31-2007, 09:28 AM
  #2638
Jake S's Avatar
not trying to be mean...but my suggestion...
search thread -> 7700 -> press enter -> read.
Jake S is offline
Old 08-31-2007, 09:36 AM
  #2639
He said he knows he can do a search but does not have the time.If your not gonna answer him dont take the time to give him a smart ass answer.
bus driver is offline
Old 08-31-2007, 09:50 AM
  #2640
its all a matter of the driver tho....and the track too.[/quote]
you got it.
