RC10B4/T4 Forum
#2432
I was always told the trick on a T4 was to add, what is it, 3 ounces to the back end: .5 oz. in each rear corner of the chassis and 2 oz. in the space between the transmission and the forward rear hinge pin mount/anti-squat block. That was just a general setup idea, one of those tricks that everybody, LiPo or not, started doing.
#2435
i have the buggy. i already put 2 1/2 oz of weight in the rear. so i guess its 3 more oz?
#2436
you only need 1.5 ounces for both cars. 3 is way too much. 1 ounce under the tranny. .25 ounce in each rear triangle
#2437
I dunno, someone told me put 2 chunks in the chassis and 4 infront of the trans, I didn't look to see how much they were
#2439
Although ask anyone who races there, none of them have any idea how I can drive a truck that handles the way mine does sometimes
#2440
Uhh I'm using bits & pieces of Chad Due's shock setup for S&N's Trackside, the rest is pretty basic (-1° camber all the way around, little bit of front toe-out, etc.). I've never actually measured my ride height, I always went by dogbones/front arms level.
#2441
Meh, I've never really worked with pro setups before. The way I see it, so what if I have, pick a name, Cavaleri's setup on my truck? I'm not Ryan Cavaleri, this isn't his truck, and even if he raced here the track's probably changed a bit since then. Near the end of last winter season at S&N's Trackside it seemed like the track was flipping back and forth between favoring ground slicks and fuzzy tires for no real reason whatsoever on a weekly basis. I think one night I even started on slicks and ended on a set of Blades up front and Hole Shots in the rear.
#2443
#2445
