Like Tree34Likes
RC10B4/T4 Forum
Old 07-31-2007, 07:36 PM
  #2386
Trader Rating: 28 (100%+)
Been running a glued saver for a couple summers now. Only way to go
I just used tire glue and it worked fine for me and has never come loose.
jbrow1 is offline
Old 07-31-2007, 07:58 PM
  #2387
POUNDITRACING's Avatar
Originally Posted by air8 View Post
LOL. Yeah nice picture. I keep breaking the part labeled "NOT" in the picture. Actually the metal turnbuckle is what has broke twice. But I haven't glued the servo saver yet. I'll see how long this lasts before it come apart again.
If you are breaking parts then I would not lock the servo saver.
POUNDITRACING is offline
Old 07-31-2007, 08:18 PM
  #2388
utahrcracer's Avatar
So are you guys gluing the blue nut on the saver after it is really tightened down basically?
utahrcracer is offline
Old 07-31-2007, 08:22 PM
  #2389
No. You disassemble the whole thing. Then glue the two plastic halves together. Then just reassemble everything and tighten the nut all the way up.
jbrow1 is offline
Old 07-31-2007, 09:27 PM
  #2390
ok thanks for the help you guys are patient I appreciate it
Old 07-31-2007, 09:53 PM
  #2391
Without patience we wouldn't last long in this hobby.
Not just with others, but with our cars!! lol
You may snap one or two bellcrank assemblies after this mod at first. I have snapped some even without it being glued before. Generally what makes it snap is if you rub a corrugated tube at speed. Jump landings and knocking wheels generally won't break anything. My T4 has been abused pretty hard and hasn't broken one in a looong time. Never broken a servo in a T4 either, glued or not.
(Knock on wood now)
jbrow1 is offline
Old 08-01-2007, 08:28 AM
  #2392
Trader Rating: 33 (100%+)
Wow, you guys got me, well, way confused. I have never had a problem with my servo savers in my T4. Or at least never had a problem that wasn't fixed with putting a new one in. I have found that if you over tighten them they will strip out and get loose, and if you take one apart, you have to be really careful when putting it back together, or you could cross thread the hex bolt and strip it out. Anyways, I have never glued one, have no problems with steering, and I run it on ozite with foams, so you would think, if there was a problem, I would notice it.
trilerian is online now
Old 08-01-2007, 10:20 AM
  #2393
i shoe gooed mine so it can give. i had totally new steering in my truck and put in steering bearings + hd spring and you could still see the wheels not turn on a high speed corner. shoe goo has some give but still hasnt come undone in 8 months.
mugenlife is offline
Old 08-01-2007, 10:43 AM
  #2394
Hey guys, how are you ?
Could you please advice me ?
i am preparing a race with my T4 but a race on a carpet track. I have no idea about what kind of tire i should use. If you know more than me, lets share your experience.
i use to buy panther or proline tires.
vision6789 is offline
Old 08-01-2007, 10:50 AM
  #2395
Tech Legend
Cain's Avatar
Trader Rating: 268 (100%+)
is this race over jumps as well?
We were allowed to use foams or road hawg / road rage tires on the T4. The problem with the foams was that we found the vehicles wanted to nose down hard off of jumps where a simple change to standard rubber tires made them jump fine. Could be something with added weight of the rotating tires bringing the front end up where the foam doesn't have that.
I would say find out what the fast guys are using, and go from there.
Cain is offline
Old 08-01-2007, 12:03 PM
  #2396
Have a look to this : http://www.petitrc.com/prcrace2007/p...pisteanim3.avi
this is a modelisation of the track.
so you can see many jumps.
i can not see what other guys will be using because it is an annual race far from my home city. i would like to prepare and buy some tires before going there. i use to race on outdoor tracks.
i'm not sure that foam tires are so good for jumping (i m afraid they will be drestroy on bad landing
Old 08-01-2007, 07:43 PM
  #2397
I ran my T4 last winter on a carpet coarse and used duratrax street tires. I was amazed at how they hooked up. I've heard alot about the tire called wiener dudes or something like that too, but never seen one. You're best bet is to email or call the place that is putting on the race and try to get some info that way.
jbrow1 is offline
Old 08-04-2007, 07:16 PM
  #2398
stanky626's Avatar
SWEET track!!!
stanky626 is offline
Old 08-05-2007, 02:31 AM
  #2399
RURC's Avatar
I scanned this thread but did not find what I am looking for .
Has anyone put the quick release from the GT2 on the B4? I have heard that there is a conversion for the T4 and I want to get that. But can it be done for the B4?
RURC is offline
Old 08-05-2007, 08:47 AM
  #2400
Are they making quick release rear buggy wheels?
FlyByWire is offline
