Like Tree34Likes
RC10B4/T4 Forum
Old 06-05-2007, 07:37 AM
  #2116
Put the ounce of weight under the bulkhead/tranny brace b/w the bulkhead and tranny. You have to use the AE weights b/c they're square, rectangular ones won't fit. WHen you put the screws back in it will hold the weights in place. You'll also hev to use a slightly shorter screw since the stock ones extend all the way through the brace and hit the weights.
cjtamu is offline
Old 06-05-2007, 11:06 PM
  #2117
does anyone have any pictures of this?
myk505 is offline
Old 06-06-2007, 07:28 AM
  #2118
Trader Rating: 10 (92%+)
Here.
Attached Thumbnails RC10B4/T4 Forum-b4-lead-sm.jpg
Johnny Carey is offline
Old 06-06-2007, 02:00 PM
  #2119
Jake S's Avatar
Trader Rating: 67 (93%+)
johnny has an offroad truck?
nah no way, prob just good with google....
Jake S is offline
Old 06-06-2007, 02:08 PM
  #2120
Moderator
Cmotif's Avatar
Putting in my 12 Turn Hand Wound Corally motor in my T4, along with my new 2.4Ghz Futaba 3PM radio. Going to be running it this weekend. Will let you know how it goes.
Cmotif <><
Cmotif is offline
Old 06-06-2007, 03:32 PM
  #2121
Yea. Best handling truck that I have ever had.
Old 06-06-2007, 05:28 PM
  #2122
Moderator
Cmotif's Avatar
What am I doing wrong?
I am not a newbie at this. Just put in my new Futaba 3PM 2.4Ghz radio, New HFX ESC and used Corally 12 turn motor into my T4.
It is running backwards.
The motor has a plus sign on the brush assembly. The red wire is connected to that side. The blue wire is connected to the opposite. My battery connector has the red side spliced into the red wire from the ESC. The black wire from the battery connector is attached to the black end of the wire from the ESC. Red to Red Black to Black.
I didn't try servo reversing because that wouldn't make sense.
Do I ignore that markings on the motor, and just switch the leads? Is there a put a motor together wrong so that it runs backwards? I matched it up with the markings that were on the can.
Cmotif <><
Cmotif is offline
Old 06-06-2007, 05:31 PM
  #2123
It sounds like your motor is 180* out.
Old 06-06-2007, 05:32 PM
  #2124
Trader Rating: 28 (100%+)
When you started using your new radio did you go thru the whole programming sequence with your speedo? You need to reprogram when you switch to a different radio.
If you had it apart you could've put it together 180* backwards. Just rotate the endbell 180 and should be fine.
jbrow1 is offline
Old 06-06-2007, 05:35 PM
  #2125
you also might have the throttle set to reverse in your radio settings
Mauri is offline
Old 06-06-2007, 06:00 PM
  #2126
Moderator
Cmotif's Avatar
Those who picked 180 degrees off, were right! Thank you very much. It runs perfect now!
Look forward to racing this Sunday afternoon! Got new tires Gladiator and Edge tires, and I am ready to RUMBLE!
Cmotif <><
Cmotif is offline
Old 06-06-2007, 08:55 PM
  #2127
Moderator
Cmotif's Avatar
OK, what is the cure from going from stupid amount of oversteer to stupid amounts of understeer?
Previously I was running Hole Shot "T" or Evil Twin rear tires and the rear would rear tires would lose grip and the back end would over pivot and the truck would oversteer.
Now with Gladiators, have great traction, but it pushes and plows.
The front tires in both cases were Edge.
Can I do something with the front springs?
C
Cmotif is offline
Old 06-06-2007, 09:08 PM
  #2128
Sounds like still a tire problem
First had to little traction, now have to much.
Where are your rear hubs at? Try moving all the spacers in front of the hub to lenthen the wheelbase. Or could try a stiffer rear spring, or put the top of the rear shock in the outer holes and see how it feels. If that doesn't work you could try a softer front spring. What antisquat are you running? Try more. Posting your full setup would help.
Rear hub position, shock angles, antisquat would be the first things I would try. Basically I suppose just go out and change something in the rear one thing at a time and run some laps to see how it feels. If you run out of things in the rear to change, then try changing some in the front.
jbrow1 is offline
Old 06-07-2007, 02:55 AM
  #2129
chris_mtb's Avatar
yay tomorrow my new futaba 2pl is coming
will put it in and take some pictures
chris_mtb is offline
Old 06-07-2007, 04:40 AM
  #2130
Stagger2's Avatar
I don't want to sound like a jerk, but lets take a look here.
http://www.prolineracing.com/products/images/8192.jpg Oversteering
http://www.prolineracing.com/products/images/8170.jpg Understeering.
This is a traction use, too little at first. Now to much. My only question is "Why gladiators?". At the plex where I race we use step-pins http://www.prolineracing.com/products/images/8097.jpg or lugnuts http://www.prolineracing.com/products/images/8200.jpg, something in that range.
Stagger2 is offline
