Like Tree34Likes
RC10B4/T4 Forum
Old 05-23-2007, 06:31 PM
  #2086
air8's Avatar
New question. what LxWxH servos will fit in the T4? I have a Hitec 625-MG which is listed at 1.48" high. It is up against the front of the battery tray. I don't believe a taller servo will fit. Any comments or suggestions for getting a more powerfull servo to fit?
air8 is offline
Old 05-23-2007, 07:12 PM
  #2087
Moderator
Cmotif's Avatar
Here are the specs for the HS-625MG as compared to the HS-5645MG. It is slightly slower than the 625 but much more powerful. Being that it is digital it will center better. Same size, same weight.
HS-625MG
Specs
Speed: 0.18sec/60° at 4.8V
0.15sec/60° at 6.0V
Torque: 5.5 kg-cm (76.37 oz-in) at 4.8V
6.8 kg-cm (94.43 oz-in) at 6.0V
Length: 40.6mm (1.59")
Width: 19.8mm (0.77")
Height: 37.8mm (1.48")
Weight: 60g (2.11oz)
HS-5645MG
Specs
SPECS: Speed: 0.23 sec/60° at 4.8V
Speed: 0.18 sec/60° at 6.0V
Torque: 143.03 oz-in at 4.8V
Torque: 164.2 oz-in at 6V
Length: 1.59" (40.6mm)
Width: 0.77" (19.8mm)
Height: 1.48" (37.8mm)
Weight: 2.11oz (60g)
Cmotif
Cmotif is offline
Old 05-23-2007, 10:54 PM
  #2088
stanky626's Avatar
Speedsterblade, thanks for all the input.
I had always figured a lighter buggy amounted to more speed. But, perhaps there is such a thing as too light. I guess that's why some are adding weight. Well, I'll experiment a little on my own.
stanky626 is offline
Old 05-23-2007, 11:06 PM
  #2089
B4Bandit's Avatar
Originally Posted by speedsterblade
example I got a alum. motor guard. weighs about 7.5 grams more than stock plastic one but the location of that extra weight gave me more traction.
Who makes the Alu. motor guard?
W.
B4Bandit is offline
Old 05-23-2007, 11:47 PM
  #2090
isnt so much as "lack of weight" as it is where the weight isnt or lack of balence.
mugenlife is offline
Old 05-24-2007, 08:51 AM
  #2091
Moderator
Cmotif's Avatar
W.
I believe Integy does!
Cmotif is offline
Old 05-24-2007, 09:29 AM
  #2092
Jake S's Avatar
Trader Rating: 67 (93%+)
trying to figure this out, for some reason the rear of my t4 feels "soft" but there is quite a bit of tension on the springs in the rear....i have trinity 30 wt w/ green spring rear, trinity 35wt w/ silver spring front.
Jake S is offline
Old 05-24-2007, 09:56 AM
  #2093
d4man's Avatar
Whats your ride height set to?? Are the shocks properly bled? When was the last time they where rebuilt??
d4man is offline
Old 05-24-2007, 06:41 PM
  #2094
I like 40wt all around. Just me though
hammer0419 is offline
Old 05-24-2007, 06:46 PM
  #2095
air8's Avatar
30w. front and 25w. rear.
air8 is offline
Old 05-24-2007, 07:12 PM
  #2096
Sounds like you have the old style threaded shock bodies. The new bodies are threaded further down. My truck is the same way.
trashedmaxx is offline
Old 05-24-2007, 07:28 PM
  #2097
Trader Rating: 28 (100%+)
WOW!! Finally somebody who runs what I run!! lol
Everybody thinks I'm crazy but I like soft setups.
For the guys with the shock bodies not threaded far enough down.. you may have the original gt threaded bodies. They are not threaded near as far down as T4 ones. I believe the shock body itself may be just a hair shorter as well.
jbrow1 is offline
Old 05-24-2007, 09:04 PM
  #2098
Moderator
Cmotif's Avatar
Where does one get a set of all the different springs. I have a T3 set, of all the spring, but they are shorter. Does anyone the part number?
C
Cmotif is offline
Old 05-24-2007, 09:13 PM
  #2099
d4man's Avatar
Click here
d4man is offline
Old 05-25-2007, 10:06 AM
  #2100
speedsterblade's Avatar
Ideally, you should ligthen all you can AND try to get the weight balanced and/or distributed where you want it. If you have lighten it some then you can move weight around where you want, without adding more weight than you originally started with. I try to get as much on the rear as possible for foward traction. but adding a bit to the front is prolly needed depending on how much steering you need or if it's not jumping right. You can also just buy some aluminium bulkhead or front suspension parts to get strength and weight on the front. ..i'm just using lead tire weights.
speedsterblade is offline
