Like Tree34Likes
RC10B4/T4 Forum
Old 05-21-2007, 03:01 AM
  #2056
wd40prerunner's Avatar
Trader Rating: 8 (79%+)
and the buggy ?
wd40prerunner is offline
Old 05-21-2007, 04:59 AM
  #2057
B4Bandit's Avatar
Originally Posted by wd40prerunner
and the buggy ?
Same result as the truck. Weight difference is negligible.
B4Bandit is offline
Old 05-21-2007, 05:51 AM
  #2058
thanks B4bandit
Old 05-21-2007, 07:57 AM
  #2059
Trader Rating: 28 (100%+)
And the plastic chassis won't short out your batts like a graphite one will.
jbrow1 is offline
Old 05-21-2007, 08:38 AM
  #2060
Moderator
Cmotif's Avatar
I forgot about that!
C
Cmotif is offline
Old 05-21-2007, 09:15 AM
  #2061
Hey. so then you guys would buy the ftt4 over the team truck? I want to build my first kit and prefer plastic over graphite but if all thats needed on the ft is a different chassis then i guess the extra hop-ups in the ft kit makes it worth while. Thanks for the thread. Dan.
danimal1965 is offline
Old 05-21-2007, 10:19 AM
  #2062
d4man's Avatar
Yes, buy the FT kit and the plastic chassis and forget the rest!
d4man is offline
Old 05-21-2007, 10:59 AM
  #2063
Moderator
Cmotif's Avatar
Originally Posted by Jake S
got the t4 body painted.....too much light though.
I like it, but what body is it. I realized that it was not a Crowdpleazer by the grill.
C
Cmotif is offline
Old 05-21-2007, 11:14 AM
  #2064
Jake S's Avatar
Trader Rating: 67 (93%+)
Its the JConepts Illuzion Body.
Originally Posted by ------
HELP ME!!!
Anyone out there want to trade a composite battery brace and factory team blue aluminum thumb screws for a factory team carbon fiber brace? would only cost each of us like $1.25 to ship out. LMK, i can't find my carbon fiber brace anymore.
Jake S is offline
Old 05-22-2007, 12:16 AM
  #2065
stanky626's Avatar
What gears are you running in your Stock B4's? I'm running a 21t pinion and 81t spur. But, my accelleration still seems a bit slow. Perhaps I need to tighten my clutch more.
stanky626 is offline
Old 05-22-2007, 01:53 AM
  #2066
Jake S's Avatar
with a co27 im running 87/18 in my t4 and its really punchie, and in the b4 im running 81/20 with a co27 also....seems punchie and has alot of top end....but none of that matters since the local track is mod 2wd and mod truck now lol
anyone have gearing suggestions for an orion v2 12x1 in the t4, and a 13x1 in the b4?
Jake S is offline
Old 05-22-2007, 03:59 AM
  #2067
What is the advantage of running the 81 tooth spur instead of the 87 spur? Im running 19/87 now is tha not good. thanks for the help.
Old 05-22-2007, 08:05 AM
  #2068
schmidt452's Avatar
Trader Rating: 15 (100%+)
In a B4 with a co27 and f brushes i was running 22-23 and the stock driven gear 81 I think.
schmidt452 is offline
Old 05-22-2007, 08:14 AM
  #2069
Boony's Avatar
Default new t4's
hi guys,
im getting two new t4's next week,these will be the team versions,can u pls highlight any majors for the build that i need to look out for
thx for the heads up
Boony is offline
Old 05-22-2007, 11:10 AM
  #2070
Aluma's Avatar
whats a good gear ratio to start with using a Novak 13.5 original motor?
Would 87/19 be okay?
Aluma is offline
