Like Tree34Likes
RC10B4/T4 Forum
Old 11-04-2006, 10:02 AM
  #1516
Tech Legend
Wild Cherry's Avatar
Originally Posted by sleepy23
are you wanting a custom aluminum top shaft? if so, that is do-able as i have a couple for my trucks. mine work great and let me use whatever type of gear on want on the topshaft( aluminum, composite, steel, titanium).
I`m not so much interested in a lighter top shaft, , interested in a more durable, longer wearing, ect ...
Maybe a coated one ?
Hook me up ....
will pay you for effort and will need more than couple top shafts if you can do....
Wild Cherry is offline
Old 11-04-2006, 10:24 AM
  #1517
i'll have to hunt around for someone that can do hard anodozing, but they defiantly can be done. i'll hunt around. can you just shoot me over a pm so i have something on file and dont forget to let you know when i can get a coater sourced?
thanks
anything else you guys would want to see. i personally have worked up a rear spool and aluminum outdrives, wheelie bar, extended inline axles...etc, for my t4's.
sleepy23 is offline
Old 11-04-2006, 10:36 AM
  #1518
Default bumps-n-jumps /indoor dirt r/c track
Sat- Nitro and electric -NOV 4
registration/open practice at 12pm--
final registration at 2:30pm--
Race approx 3:30pm till when done
fee is $15 first vehicle & $5 each additional
we will set classes with what shows up--so bring what you got.
31st lorain ohio.
contact :
[email protected] 1-877-897-0430
steve 1-440-385-0184
JR@SHS is offline
Old 11-04-2006, 11:51 AM
  #1519
Davidka's Avatar
Trader Rating: 85 (100%+)
A hardcoated aluminum top gear/shaft would be great. Basically a copy of what the losi cars use. They wear forever and are light.
thanks
Davidka is offline
Old 11-04-2006, 07:43 PM
  #1520
schmidt452's Avatar
Trader Rating: 15 (100%+)
If any of you have a factory team b4 roller that you would like to part with for some cash send me an e-mail, I am looking to pick up another class.
[email protected]
schmidt452 is offline
Old 11-04-2006, 11:42 PM
  #1521
WheelNut's Avatar
I'd take a hard ano'd top shaft! Aluminum outdrives are interesting to, but I would imagine they wouldnt last long?
WheelNut is offline
Old 11-05-2006, 02:18 AM
  #1522
old_fart_racing's Avatar
Personal transponder location.
I was just wondering where everyone thinks is the best spot to mount there personal transponder on there T4?
I have mine mounted on the steering servo but would like to mount it farther forward but cant find a good safe location.
old_fart_racing is offline
Old 11-05-2006, 06:19 AM
  #1523
you could try to mount it above the front chassis brace but i would be concerned that it is too far from the ground and might miss a lap count....not sure though. i've got mine on the servo as well and haben't had any problems in 4 years.
adam lancia is offline
Old 11-05-2006, 09:17 AM
  #1524
nutfluff's Avatar
I've been mounnting mine on the servo for years. Are you losing races by tenths where mounting it closer would help????
nutfluff is offline
Old 11-06-2006, 08:45 AM
  #1525
jeff jenkins's Avatar
Trader Rating: 82 (100%+)
i just mount mine on the side of the chassis where the esc is located and to be honest it's only going to help to mount it further if you are in a photo finish. which happens rarely. i just dont put mine on the servo because the chance of causing a glitch.
jeff jenkins is offline
Old 11-06-2006, 09:26 AM
  #1526
Post
No, I was just wondering if someone had a better idea of mounting the transponder up farther,so it could be read that much sooner. Guess I will just keep it on the servo.
Old 11-07-2006, 05:50 AM
  #1527
What's the best way to mount the transponder if you're using the track's and don't have a personal. I'm getting ready to start racing and need to have a place to mount it.
calyakker is offline
Old 11-07-2006, 08:04 AM
  #1528
if you dont have a pt i would just mount it in the front window of the body. it's the closest you can get it to the front of the car.
Old 11-07-2006, 05:04 PM
  #1529
Do all transponders have the post on them to clip to the body?
Old 11-07-2006, 05:19 PM
  #1530
WheelNut's Avatar
Calyakker- If your running a T4 you can make a little U shaped mount out of lexan and tape that to the chassis. Then just put a hole in the mount and clip the transonder to that. An AMB handout wont fit beside the Rx unless the Rx is really tiny (I run a Novak XXL and it wont fit).
WheelNut is offline
