Traxxas 2wd Slash Thread
#2418
finally done!
my slash with the traxxas LCG kit installed.
-original trx servo
-original trx receiver + waterproof box
-hobbywing ezrun 60A esc
-tacon 10t 3500kv motor
-rpm gearbox housing
-hot racing diff with 20k oil
please excuse my amateurish/ugly wiring. I am running 23/90 gearing. I am going to be running some mod 2wd sct class racing with this. hopefully get some educational racing experience under my belt and some decent results before springing for a higher end motor/esc combo (8.5t or 10.5t sensored motor)
i did notice some cogging with the tacon motor.
-original trx servo
#2419
That LCG chassis looks good. Since I'm low on money I'll take my time on rebuild. I did notice my sealed differential mod on the stock differential held up real well from a summers worth of weekend bashing. I'm just going to put it back in the way it is. And if I go even slower I might just order another Hot Tranny case since it looks ay cool. I never had a problem with motor heat all summer. It just that when things broke I had to get another chassis. The stock chassis cost me $5.99 on eBay so I guess that isn't too bad.
#2420
I have a slash with STRC LCG/Rustler chasis which I want to convert to onroad for my son as a gift. Right now, I have a PF8-GT body and few items on order.
AKA 17mm hex
1/8 wheels/tires premounted
What else do I need to complete this? Do I need the rustler bumper and body posts for this 2wd?
I've asked at another forum but there's very little traffic over there. hopefully I can get answers because my web search isn't going so well.
THanks in advance.
AKA 17mm hex
THanks in advance.
#2421
I hve the same esc.....not to bad, i eliminated the bullets t , and soldered directly to the motor/esc.
#2422
MIP Speed Tips
I was in the market for some hex tips for my new Ryobi driver; sought out MIP specifically since I've had great luck with their drivers since the late 80's.
they should arrive soon. I already know they're worth the money.
Thanks MIP for making the best stuff out there.
#2423
Oh yes they are....I'll never buy cheap tools again
#2425
Bypass valving?
On the bypass system 12mm #7 piston on an SCTE at what thickness would you say would the rebound be equal to a standard piston 50/50 ratio? .020?
#2427
If you insist on doing that then you might want to go back to stock pistons.
