New Reedy Sonic Brushless motors
#31
Motor Timing at Endbell...
Hope this helps.
#32
Tommy,
If you plan on running Blinky Mode the SXX V2 you have now will work great with the Sonic 17.5. You may want to consisder upgradeing to the larger rotor option at some point due to the larger gearing we pull in blinky mode. the SXX Stock Spec only offers more aggresive timing profiles for stock motor racing which will have no effect on performance if you are racing Blinky class.
Hope this helps and good luck!
Is this the larger rotor here? http://www.amainhobbies.com/product_...Sintered-Rotor
Thanks again!
#33
Just picked up the 17.5
No power and feels like 100% drage brake... and gets very hot fast.
Anyone else have this issue and how long does their warranty take to get a new one back?
#34
check 3 timing's screew. If they are loose you have variable timing (result no power and motor come's very hot).
Set timing as standard and tighten 3 timing's screew
hope this help
hope this help
#36
Took the whole motor down to check everything.
Looks fine, tried it on 3 different speedos...
Already sent out looking forward to getting a good one
#38
I seem to be having an issue with my Reedy Sonic 8.5. I cant figure out what gearing this motor wants. I am running a 2WD buggy with an FDR of 8.99 and temps are 117 degrees. I am having to boost it with my Tekin RS just to keep up in the mod class. Currently have boost set to 40 degrees.
According to all the people at my local track I should not have to boost this motor at all and it should be a rocket ship, but it isn't. I have experimented with changing my gearing I even went all the way down to a 7.70 FDR with this motor, and while it picked up top end I lost punch.
Any suggestions as to what I may be doing wrong with this motor?
Thanks for the help guys.
#39
Anyone with this motor?
#40
Yes I've got a 8.5 on my RC10B4...and the ratios that you are using are good.( and I've got the RS )...for 8.5 Reedy you can go from 8.00 to 9.00...depend on the track...down 8 from my point of view it will give more difficulties to the motor to get his RPMs.
Think that, with the "timing" on the motor, you've 15° at 0 tab of timing.
40° on the boost is too much from my point of view.
Usually, on slippery tracks with my RS & Reedy 8.5 ( with 1 or 2 tabs of timing ) :
- Drag brake = Off
- Min Throttle = 10 ( I set sometime at 6 for slippery tracks )
- Timing advance = 0 ( C2 )
- Boost = 27
- Start RPM = 5000 ( 3000 if you want more punch )
- End RPM = 20000
- Curve profile = 3
I use Turbo sometime
Turbo = 17 with ramp 2 and delay at 0.
And with that configuration, during hot weather ( 35°C - 40°C ) down the sun...I never be at 117°C...be care with the timing.
Have you verify the ball bearings of the motor ?...and verify that your transmission is "free" ?
- Drag brake = Off
- Boost = 27
- End RPM = 20000
- Curve profile = 3
#41
- Drag brake = Off
- Boost = 27
- End RPM = 20000
- Curve profile = 3
- Drag brake = Off
- Boost = 27
- End RPM = 20000
- Curve profile = 3
#43
So figured out the issue. There were actually two issues. One was with the ESC itself. RPM range was slightly outside of of the track layout. So brought boost start rpm down a little. Second was gearing was way too tall and wasn't letting RPM's ramp up to a useable band for this motor. (I felt like such a noob) Anyways now that its all sorted out this motor is a monster!! Love it. Runs way cooler then my other mod motors by a decent margin.
Thanks for the help Bastos!!
#44
Has anyone used these motors in their short course trucks? if so, what did you think and should it be geared as the LRP X12 are?
#45
Come on guys, someone must have used this motor in a short course?? really looking for some input
