ofna/hobao hyper7 conversion
i have ofna hyper 7 nitro car and now i want make it to brushless.
can i use this motor and esc system and 4cell life battery. are motor and esc too smal? |
Originally Posted by jonu93
(Post 9307592)
Originally Posted by kufman
(Post 9307603)
I am guessing that you do not have enough posts to be able to post a link... or you just forgot it put it in. What system are you trying to use?
Scanner RC PowerSquare 2600kv Racing 550 Motor ZIPPY Flightmax 4200mAh 4S2P 30C LiFePo4 Pack |
I would say you need more of a lower kv rated maybe like a 1900 or 2200.
Originally Posted by stunter38
(Post 9307636)
(Post 9307621)
hobbyking 100a esc
Scanner RC PowerSquare 2600kv Racing 550 Motor ZIPPY Flightmax 4200mAh 4S2P 30C LiFePo4 Pack http://www.hobbyking.com/hobbyking/s...dproduct=14635 http://www.hobbyking.com/hobbyking/s...dProduct=10370 The motor might work, but it is a little on the small side for 1/8th. The following might be a better idea. http://www.hobbyking.com/hobbyking/s...dProduct=14632 The battery you are looking at appears to be a good match for your application. The rpm ratings on the motors should work on a 4S LiFe battery. |
(Post 9307650)
why. someones uses 2800kv motors but is thisd scanner rc 550 motor too smal on 1/8 car or need it be something XL motor
(Post 9307656)
The ESC is for planes and I am not sure if it will work for a car. It will need a separate BEC or receiver pack since it does not have one built in. You would want something more like the following. I haven't owned either one, but they are built for cars.
The battery you are looking at appears to be a good match for your application. The rpm ratings on the motors should work on a 4S LiFe battery. why i cant put url link's here? |
(Post 9307681)
i mean hobbyking 100a brushless car esc with reverse. i want cheap motor and esc.
(Post 9307696)
This site restricts new users. I think you need to have at least 15 posts or something like that before you can post links.
whic is better car inferno st or hyper 7 |
get the turnigy trackstar
and I would go hyper 7 cause its cheaper kyoshos are great but their parts can get spendy some times |
| All times are GMT -7. It is currently 09:50 AM. |
