Rc help rx8 hotwire
Rc help rx8 hotwire
I hooked up hotwire to a sc104wd I have a 2 lipo and set it all up was running the it stopped and all the lights were on the esc I turned it back on and same thing the motor was cool and battery was fully charged what am I doing wrong can someone please help I also tried to re calibrate the recover and esc and it just makes a constant beeping noise I'm so list guys. Please help if you can. Jay
Rx8
I think at one point the battery was connected and what plug are you talking about thanks jay
Rx8
Rite now when I turn it on all LEDs r lit steady and not blinking and the is no light on in the reciver thanks jay. Wow this stinks guys
All lights simply lit means something is way out of sync. What did you do JUST prior to this issue?
Update the software? Change a setting?
You can start over from scratch by simply performing a factory reset and re input your settings for lvc, etc.
Ivc?
Would u be able to explain how to re enter the software I have windows vista the truck is working now I'm just scared to hook up hit wire to it. Please help Randy with this ur my only hope. Thank you for you time. Jason
Rx8 hotwire help with Randy pike
Just b4 thus problem I think I may have updated software I'm not sure but as of now the truck is running should I hook up to hotwire again. Thanks again Randy jay.
Is it worth hooking up hotwire
Just with the rough time I had with the first attempt I'm not sure if it's worth it thanks jay
I can't really understand what you're saying.
