HELP! cogging
Old 06-19-2011, 03:10 AM
yoshimonster's Avatar
Exclamation HELP! cogging
hi i just upgraded my hsp xstr to brushless and lipo
i got the ezrun 8.5t 60amps brushless combo
and i got a zippy flightmax 5000mah 20c 2cell lipo
its cogging a bit when i put the throdle down a bit but then after that its fine.
i dont know if the motor gets hot because i have only driven it about 3-4 times and only up and down the driveway and i havent been able to go full throtle.
my gearing is 23Tooth Motor Gear, 64Tooth Spur Gear
so can i pls have help i think i have to change my gearing but i dont know what to.
yoshimonster is offline
Old 06-19-2011, 06:51 AM
Trader Rating: 17 (100%+)
It could be slightly overgeared, but not enough to make cogging more than noticeable. I would first check all of your connections very closely, a loose motor plug or solder joint can cause this. If you are sure that every connection is solid then you can try to lower the timing on the ESC settings and see if it improves.
burnineyes is offline
Old 06-19-2011, 02:55 PM
ok will try
Old 06-20-2011, 01:26 AM
hi my conectors that conect the motor from esc are just blue bullet conectors that arnt gold plated just greyish medal that you cramp. i brought them down at the local hardware and i just wanted to know if there good enough or do i go and buy some hobby-grade gold plated bullets that you solder
Old 06-20-2011, 01:45 AM
Super Moderator
nexxus's Avatar
Trader Rating: 310 (100%+)
There's your problem!
They won't handle the amp load, spend some $ on decent connectors!
nexxus is offline
Old 06-20-2011, 08:58 AM
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Not true at all.. if you measure the resistance difference between those and a gold plated bullet connector, it will be practically nil. The only advantage to a gold plated connector, is corrosion resistance. This is NOT your issue.
Cpt.America is offline
Old 06-20-2011, 10:58 AM
The resistance between a gold bullet connector and a very high quality butt connector may not be much when you measure the connector itself. The difference is the quality of the crimping and the quality of the butt connector compared to the quality of the bullet and solder joint. I would bet money this is the problem.
Old 06-22-2011, 03:09 AM
Exclamation
well i just brought some conectors for my esc and motor if it doesn't fix it then i will tell you
