Batteries
Old 06-18-2011, 02:11 AM
OMG23RC's Avatar
Trader Rating: 21 (100%+)
Exclamation Batteries
Hi guys i just got the new Venom Pro Balenece Charger and i was just wondering what amps do i charge a
NI-MH 7.2v 3600 Mah:
NI-MH 7.2v 3000 Mah:
NI-MH 7.2v 2000 Mah:
Without them overheating.
OMG23RC is offline
Old 06-18-2011, 07:39 AM
3.6 amps for 3600 3 amps for 3000 and 2 amps for 2000 or 8.6 amps in parallel.pretty hard to figure out huh? haha jk
tman48 is offline
Old 06-18-2011, 05:04 PM
OMG23RC's Avatar
Default Ok
K cool so for example I have a 4300 mah battery it would be 4.3amps?
OMG23RC is offline
Old 06-18-2011, 05:37 PM
Trader Rating: 17 (100%+)
The key to not overheating nimh cells is your peak detection setting on the charger. Different packs might like different settings, start with the lowest setting, I think it is 5mv. Check the temp of the pack as it approaches full charge, it should reach about 120-125F max. If the charger stops before it reaches at least 110F, I would recommend to increase the detection voltage until it does. This will ensure you are getting the fullest charge possible and max performance.
The actual charge rate of sub-c nimh packs is not that critical, but I would not exceed 4A for maximum longevity. Lower rates will give less punch and longer life, higher rates will give more punch and shorter life.
burnineyes is offline
