Suggestions on 2wd buggy rear tire choice? >
Old 06-10-2011, 11:23 AM
1320VR4's Avatar
Trader Rating: 15 (100%+)
Default Suggestions on 2wd buggy rear tire choice?
I've got a 22 and I have it set up for mid motor right now. I run on a track with baseball diamond style dirt. I'm running Caliber tires on the back of it and when the track is wet, it hooks up pretty darn well. When the track dries out I can't put ANY power down at all. I don't mind swapping tires out between heats and mains since the car already comes with two sets of rims. What tires would you guys suggest in the rear that will for sure help foward motion.
I'm sure a rear motor configuation will put more weight over the drive wheels and help it hook up but thats terribly ununique and boring
Matt
1320VR4 is offline
Old 06-10-2011, 11:33 AM
Jstall7543's Avatar
From what I've seen on the 22, the Jconcept barcodes, gold compound delivers extream traction when lightly sanded and tire sauce is used they hook so good you can hear it gripping with a little tire howl! So dialed! Hope this helps.
Jstall7543 is offline
Old 06-10-2011, 12:18 PM
rangerjkb's Avatar
Trader Rating: 41 (100%+)
Recommend checking out what the other fast 2WD buggies are using for rear tires and possibly try those. If there is any dust on top of the racing surface, I'd recommend a small pin tire, ie. Jconcepts Goosbumps or something similar. If no dust, would definitely recommend the Bar code, etc.
rangerjkb is offline
Old 06-10-2011, 12:50 PM
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Matt
Yeah.. running a winning setup IS boring. If that's the type of dirt you are running on, mid motor is going to suck.
Cpt.America is offline
Old 06-10-2011, 02:19 PM
Cannondale1974's Avatar
Trader Rating: 30 (100%+)
Tire sauce for off-road? Where do you get this stuff?
edit: nevermind, found it.
Cannondale1974 is offline
Old 06-10-2011, 08:39 PM
Muggydude's Avatar
Trader Rating: 92 (100%+)
Bar codes excel on hard pack low/no dust surfaces like clay. Definitely not baseball type dirt!
Muggydude is offline
Old 06-10-2011, 10:10 PM
vr6cj's Avatar
Trader Rating: 124 (100%+)
+1---million
I would go to a pin type tire. Step pins, Calibers, Hole shots, Double Dee's etc.
vr6cj is offline
Old 06-10-2011, 11:41 PM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
agree....
you're not going to find a tire that's going to compensate for the lack of rear grip of a mid motor set-up, the design isn't meant for that type of surface plain and simple. If you feel you MUST run mid-motor then best of luck.
X-factory guys will disagree but to them I say...
racer1812 is offline
