lipo help please.
lipo help please.
hey guy i just need some quick help. i'm new to lipos and need to be reminded on how many amps i can charge the battery if the battery had a 4c charge current and so on. also have a 2c charge current battery.
thanks.
thanks.
multiply the capacity by the charge rate.
5500mAh with 2C charge rate = 11A
That is the max though. I don't charge my batteries that high.
Here is a great resource for understanding.
rchelicopterfun.com/rc-lipo-batteries.html
alright thanks man
so i have a pack that has a 4c charge rating with 3000mah which would be 12 amps, right? so i can safely charge my pack at 6 amps? or would that be a bad idea?
6 amps should be safe if your charger and power supply can go that high....most chargers are 5 amps max...and I have seen many 10 amp chargers turn down or have issues due to low input from power supply charging at that level.
I usually just charge all my batteries at 2 amps.....if I am at the track and have to rush I will go up to 4 amps
all my packs are 4000mah 25c or higher so they could charge much higher..... but I still just use 2 amps
