How much harder can I gear a 1406 4-pole vs cm36?
Hi, first post on this great site!
I'm hoping for input from people who have experience with the 1406 4-pole and cm36 2-pole Castle motors. I'm trying to figure out which pinion to order to use with my new 4-pole motor. I know running and temp'ing is my best bet, but I'm curious as to what you guys are getting away with. I'm ran a MMP w/ cm36 5700kv 19/82 (2s) on my Kyosho RT5 and highest I've temped it so far was ~166. That's after 2 packs through it at WCRC. My 1406 4-pole just came in and supposedly it's more efficient and 30% more powerful. Do you think a 21 or 22 tooth pinion is do-able on this new motor? Thanks guys, looking forward to hearing your responses :) |
I think is doable especially since the new motor is much lower KV. I would say put the 22t on there and see what the temps are like and go from there.
This chart so help you out with your Castle Motors.
http://www.castlecreations.com/suppo...ring_chart.pdf |
Thanks for the replies!
I saw that castle gearing chart and I think it's way on the safe side. Anyone know what the 1406 5700kv is comparable to in the Orion line up? |
