Tekin Pro 4 Short Course motor Sneak Peak >
Old 12-20-2011, 08:41 AM
  #2446
rcq
Originally Posted by Casper View Post
How fast do you want to go or how big is your track.
For really tight techinical tracks the 4000 maybe a better choice. The 4600 is great for open tracks, speed runs or higher traction.
There is our Track:
http://rc-cars.lt/index.php?option=c...d=401&Itemid=2
rcq is offline
Old 12-20-2011, 08:47 AM
  #2447
Evilgies's Avatar
I raced the pro 4 4600kv for the first time last weekend.
I'm a fan now, best motor for SC 4x4 ive ever owned.
And I owned 4 other motors before this one.
Evilgies is offline
Old 12-20-2011, 08:48 AM
  #2448
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by rcq View Post
4600
Casper is offline
Old 12-20-2011, 09:07 AM
  #2449
Integra's Avatar
Im lovin the ship rope for piping, Seen that quite a few tracks around the world. Never on this side of the pond however. Curious where do you guys get it ? Is it Not usable by Sea going vessels ?
Integra is offline
Old 12-20-2011, 09:22 AM
  #2450
rcq
Our tracks is about 300km to the dock. Ships are changing it like they are old (out of date). So we get it for free it.
rcq is offline
Old 12-20-2011, 09:56 AM
  #2451
specgie's Avatar
Trader Rating: 79 (100%+)
Anyone know if the pro4 4000kv is fine for use with LRP's new ix8 esc? Just got it in from AE and in theory it should work fine, right? Being an 1/8 scale esc?
specgie is offline
Old 12-20-2011, 10:01 AM
  #2452
Team Tekin
Randy_Pike's Avatar
It should, make sure to remove any timing the esc has internally.
Randy_Pike is offline
Old 12-20-2011, 10:10 AM
  #2453
Casper's Avatar
Anything rated for an 8th scale should work just fine. Just make sure the 8th scale ESC is rated for 2S!
Casper is offline
Old 12-28-2011, 02:20 PM
  #2454
10sctrel0v3r's Avatar
Randy, thank you for the support and quick replys with me. just received the bearings today. thank you and tekin
10sctrel0v3r is offline
Old 12-28-2011, 05:33 PM
  #2455
Trader Rating: 31 (100%+)
Randy Pike you have PM
adubaz7 is offline
Old 12-29-2011, 08:14 PM
  #2456
snellemin's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Randy_Pike View Post
Send me a link to what you're using now...I'll take a look.
Better late then never heh. Here's a pick of some of the smaller motors that I use. I did get me a Tekin 4600 as you can see. I haven't used it yet though. Currently running the B50-5s Hacker in the RCM CRT.5. I had to add some caps to the ESC and use the torque control on the esc. I still need to find that elusive 2s 5000mah lipo that can deliver what I need.
Rotor magnet of the 4600 measured 19mmx20mm.
snellemin is offline
Old 12-30-2011, 01:07 PM
  #2457
I have a CC MMP esc at the moment, and was thinking of getting a tekin pro4 4600kv. What is required to operate the motor? BEC or any other stuff?
Want this to work until I can get the money for a RX8 esc which wont be until summer more than likely.
TNKrc is offline
Old 01-02-2012, 11:34 AM
  #2458
Trader Rating: 33 (100%+)
i think your going to need to get a BEC anyway.. thats the only way to keep them from browning out under high amp draw..
dgrobe2112 is offline
Old 01-05-2012, 07:03 AM
  #2459
JPG
JPG's Avatar
Just soldered up my new Pro4 4600 and RX8 in my new SCTE. Seems to run fine in forward, but has a jerking-non smooth reverse. The more power you give it the smoother it becomes, but at slow speeds its almost as if the motor is slightly hesitating causing the whole truck to display this jerky vibration.
Any help or ideas, or is this normal?
JPG is offline
Old 01-05-2012, 08:07 AM
  #2460
Team Tekin
Randy_Pike's Avatar
Not normal, make sure your sensor harness is full seated. IF it is, try unplugging it and see if this changes the condition.
