Swelling lipos
Swelling lipos
Hey Pretty much all of my lipos are swelling when they are used, They are hard case and some of them are pretty darn expesnsive batteries. It doesn't matter which car or esc I use. Is this normal? if not is there some setting I should change so that they don't do this
R/C Tech Elite Member
The worse thing that can happen is if they puff during charging. Don't use them again if that happens.
thats probably it! they only swell when I use them but usually I charge the night before then head to the track
Super Moderator
Trader Rating: 31 (100%+)
+1 on previous posts. Check with your type of battery, it should have a storage recommendation for storage charge level and temperature. This happened to one of mine several years ago and I believe it was due to leaving it sit in a charged status. Also, depending on the age/usage, eventually they will go bad.
dont tell me you use smc lipos
they swell easily
i bought a pack for $130 + shipping and it swell in few months under 10 charges with no over/under charge or over heat. charge with 4amp (under 1c)
they swell easily
i don't run any particular brand, I buy whats on sale or what seems like a good deal at the time. I have some Orions a few venoms and a couple thunder power batteries. I think the batteries are getting too hot. How do I fix this?
proper care
I have a couple sets of lipos Ive had for a few years, never had a problem I store them fully charged sometimes for weeks on end, in a cool dark place ( in an old ammo case in my garage) These lipos have been charged more than 100x or so ( lots of cycles ) They are still just as strong as the day I bought them. I have seen others swell their lipos by running them too HOT -over geared-or-under geared- and running them past lipo cut off. I ALWAYS let my lipos cool down completely before charging, and very rarely run them to cut off-- for 2 reasons, #1 damage to $100 battery, #2 cuts down on charge time.. ( I run 4s packs ) I think with good care these batteries will last a while longer.
i just toke my lipos out of storage abit ago they are 5000mah but they are only taking 3500mah or so they were fine befor i ran them on storage in fall dont understand,any feedback? thanx
