Serpent 811E Buggy Thread >
Like Tree3Likes
Old 01-29-2014, 05:53 AM
  #4516
Would really be interested in checking out his setup.
Great job!
Voltron989 is offline
Old 01-29-2014, 02:58 PM
  #4517
Trader Rating: 83 (100%+)
New to Serpent so just want to be sure, the gen 1 tekin T8 1900kv motor fits this car correct?
And does anyone know where i can find the semi painted avenger body?
bigbeej is offline
Old 01-29-2014, 07:39 PM
  #4518
nthunberg89's Avatar
Trader Rating: 6 (88%+)
Yea i ran the shorties at race em and they feel pretty good. Im running it with the lipos all the way forward. I do have a slight push with it. Im going to order a hard servo saver spring before i decide to change the set up.
nthunberg89 is offline
Old 01-30-2014, 04:51 AM
  #4519
Maxxingout's Avatar
Trader Rating: 17 (100%+)
Yup, that's what I have in mine.
The hard ss spring does help. Not sure it'll completely cure the push but it's def a good upgrade.
Maxxingout is offline
Old 01-30-2014, 08:51 AM
  #4520
AcKais36's Avatar
Originally Posted by chicky03
I should have it all done on monday.
Any update on when the setup sheet will be available to view?
AcKais36 is offline
Old 01-30-2014, 06:40 PM
  #4521
Do any other bodies other than the stock and avenger fit the buggy? Any of the bulldog bodies?
bigbeej is offline
Old 01-31-2014, 07:31 AM
  #4522
orcadigital's Avatar
Trader Rating: 61 (100%+)
I am running the same motor and yes it fits fine. I am not aware of a semi-painted Avenger body yet, just the stock, but I could be wrong as there is an SRX one I was not aware of either.
Not really. Way back in this thread someone had gotten a Losi body to work, but it did not hug the chassis correctly. I'd go stock or Avenger depending on if you want cab forward or not.
orcadigital is offline
Old 02-01-2014, 02:41 PM
  #4523
JasonR/C's Avatar
Just jumped on the serpent wagon! So far in this build ive noticed one thing. Binding in the front bulkhead. The diagram from the shim placement was hard to read. Any tips?
JasonR/C is offline
Old 02-01-2014, 02:46 PM
  #4524
RCmayor's Avatar
Gear mesh you mean? If yes it will go away after the first few runs.
RCmayor is offline
Old 02-01-2014, 03:20 PM
  #4525
JasonR/C's Avatar
If I take the front wheels and spin them forward its not smooth its really gritty. No electronics in car yet.
JasonR/C is offline
Old 02-01-2014, 04:01 PM
  #4526
Trader Rating: 42 (100%+)
Welcome to the madness. Now I have to get you using Speed Passion.
Mine was tight per instructions. I did a trial and error with shimming. After my first few packs it's all smoov.
Nexus is offline
Old 02-01-2014, 08:25 PM
  #4527
2 things, remove the retaining screw on the gear side(I don't feel you need it), and loosen the lower diff case screws, i even run a .5mm shim to keep the case from squeezing the diff when assembled.
jsorwell is offline
Old 02-01-2014, 08:56 PM
  #4528
dan_vector's Avatar
Trader Rating: 27 (100%+)
I've built 3 of these and it has always been the same and In the rear I run 2 shims (0.1mm ea) on the pinion and no shims in the front pinion and mine was pretty smooth out of the box. That's without loosening diff cases and such like. After about 4-5 hrs on the car the gear mesh is still spot on and generally the transmission is a smooth as silk! Enjoy the car it's awesome.
dan_vector is offline
Old 02-01-2014, 09:15 PM
  #4529
JasonR/C's Avatar
Thanks Joe and Dan!
Thanks nexus!
JasonR/C is offline
Old 02-02-2014, 12:52 PM
  #4530
AcKais36's Avatar
Can someone help by explaining to me the differences between all the different suspension brackets? I have the serpent 1/8 rtr ebuggy and recently broke one of the rear cheap plastic ones that came stock. (600551 -$6) I've always been a firm believer of you brake it, you upgrade it. So what in the world is the difference between the 3 other machined options? They are all the same price on serpentamerica so I don't know how to decide, and they all seem to be the same. Any help is greatly appreciated. Thanks
AcKais36 is offline
