Serpent 811E Buggy Thread >
Like Tree3Likes
Old 07-24-2011, 04:45 AM
  #181
pointforward's Avatar
Originally Posted by Stealth_RT
Better yet, get rid of the bullet connectors and solder the wires directly to the motor. Bullet connectors are just asking for problems on an e-scale. They are high resistance, vibration suseptable weak links in your electronics. I don't even like lipos with plug in bullet connectors for e-scale. Its just begging for a failure or intermittent operation. Stick with direct soldering everything you can, and use Deans or Traxxas connectors for your batteries. Lessons learned the hard way by the pioneers of the class, when the electronics and batteries weren't so good, and any weak links lead to bigger problems.
I would disagree with you on the Deans for batteries. I've had too many failures with Deans not to mention too many times having felt the connector dangerously hot. I've been using the thick Tekin bullet connectors insulated on the outside of the female plug for batteries and haven't had that fail ever since.
pointforward is offline
Old 07-24-2011, 05:16 AM
  #182
Pulse_'s Avatar
+1 Rather go for bullet connectors or EC5
Pulse_ is offline
Old 07-24-2011, 06:31 AM
  #183
Who8mySandwich's Avatar
What it iz Brown, what it iz?
Who8mySandwich is offline
Old 07-24-2011, 08:57 AM
  #184
Frank L's Avatar
Trader Rating: 148 (100%+)
Deans do get hot and I have only had a deans fail 1x where it came loose but I was bouncing an E truggy around pretty hard
Frank L is offline
Old 07-24-2011, 04:17 PM
  #185
Jmuck69's Avatar
Trader Rating: 14 (100%+)
saw these on Neobuggy
Attached Thumbnails Serpent 811E Buggy Thread-serpe1.jpg   Serpent 811E Buggy Thread-serpe3.jpg   Serpent 811E Buggy Thread-serpe2.jpg   Serpent 811E Buggy Thread-serpe4.jpg   Serpent 811E Buggy Thread-serpe5.jpg
Jmuck69 is offline
Old 07-24-2011, 07:44 PM
  #186
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
I use Dean's for all my electrics. Haven't had one fail yet.
heavyjeffd is offline
Old 07-24-2011, 07:59 PM
  #187
Jube's Avatar
Trader Rating: 43 (100%+)
They can fail and I've seen em hot many times. They aren't rated for the amperage 1/8 buggies and especially truggies can draw. I personally use EC5's without any issues for almost 2 yrs in my scales. They will never come apart on their own, hell they're tough to pull apart and they're rated plenty high. Most Deans failures I've seen are them coming unplugged during a race.
Jube is offline
Old 07-24-2011, 08:00 PM
  #188
heavyjeffd's Avatar
Try this instead: http://www.absolutehobbyz.com/produc...oducts_id=6131
It's $10 less than the nitro version. Throw in the discount codes and I don't see why anyone would complain.
What's the code?
Old 07-24-2011, 08:01 PM
  #189
heavyjeffd's Avatar
I always strap down all my wires/connectors so nothing flops around. Guess I've been lucky.
I can see it on 4S (using a higher amp connector), but these are 2S batteries. I've had a fine record with Deans on 2S.
Old 07-24-2011, 08:58 PM
  #190
teeforb's Avatar
Trader Rating: 94 (100%+)
Anyone know the cost to convert from nitro to s811e setup?
teeforb is offline
Old 07-24-2011, 09:16 PM
  #191
BLbound's Avatar
Trader Rating: 27 (100%+)
This buggy looks sweet! I can't believe they are going to beat team Durango to market!
BLbound is offline
Old 07-24-2011, 09:49 PM
  #192
Oldanski311's Avatar
It makes you laugh when you think about how much of Durango's sales will be taken by this buggy. I think TD made a bad decision releasing info of the Dex408 so early, I think that sparked Serpent's interest in releasing the 811- be. We all have been waiting for a quality version of this layout and Serpent is ahead of the game.
Oldanski311 is offline
Old 07-24-2011, 10:02 PM
  #193
serpent was the originator to that buggy's design too. Anyone know what the exact Be's battery case dimensions will be?
jasonwipf is offline
Old 07-24-2011, 10:36 PM
  #194
Well I self answered a few questions. It appears as if the length is 139mm so i can hold a pack 138mm or less. and the width is 48 so 47mm or less pack will work but I have no idea about the height. the height will be pretty important since it seems as if the swivel batt top holders are fixed and it will have a maximum height it will accept. anything less and you may have to put foam to compensate.
Old 07-25-2011, 01:55 AM
  #195
Pulse_'s Avatar
Would be interesting to run two 3S lipos in it with a low kv motor
Pulse_ is offline
