Lipo balancing
Lipo balancing
I've always hooked up my balance plugs when charging my lipos ,2s,3s and 4s. Usually charge on my Hyperion duo 615 . Question is are the batteries actually being balanced? My brother says that you have to use the balance option on the chargers and that just using the normal charging option, they aren't getting balanced.
You should be able to push a button and see the voltages per cell while charging. I have a icharger 208b and I have to select balance charge. Then I can press the left or right arrow buttons and see voltages of each cell and options in the settings screen. You always want to balance charge if you can.
Terry
Terry
hehehe
While you are charging the lipo. Push the left button two times and then push the up button one time. This will get you to the balance screen and you will see the individual cell voltages. This is the screen that I look at every time I charge. It will tell you how close to being done the battery is. It will also tell you how far down you ran the lipo.
Super Moderator
Trader Rating: 31 (100%+)
I don't think the balance mode does anything but balance, as in it's not a charge mode at all. My Hyperions always balance charge as long as the balance leads are connected. If they're not connected it reads "balancer advised" and you have to press the start button another time to start the charge.
Super Moderator
then using that same mode with the balance lead will balance charge the pack.
