????Best Servo Tape???
#17
Yep the Parma Pro Servo Tape 8044 is the number. It is clear and kinda gummy.
#23
If any of you guys are near an auto body supply store 3M makes adhesion promoter pads- part # 06396. They are one time use but will give you a near permanent bond on your ds tape. Just don't use it if you plan to swap your electronics in the near future- cleaning the residue off is no easy task...
#24
I just use the 3m double sided tape I picked up at the hardware store. I make sure both surfaces are clean. The longer I can let the tape sit before driving the better. The only times I have had trouble is when I drive right after putting it on.
#26
Super Moderator
Trader Rating: 31 (100%+)
I guess if you can't figure out the overly complicated instructions that come with all the different brands of "servo tape" Shoe Goo will work
#29
R/C Tech Elite Member
+1
I tried the red Parma tape and it works ok, but I like the MIP servo tape better. It's to the point where if I see it in a hobby shop, I buy every package on the shelf
They (MIP) are obviously getting the tape from a larger roll or sheet; and as soon as I locate a source for it, I'll never need servo tape again!
#30
+1 for Parma servo tape
