Old 10-19-2004, 12:15 PM   #61
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Default Buying an engine for my FT RC10GT
Hi guys,
Besides OS .12 CVR (s) and .12 CVRX (s) wich other engines can be mounted without modifications on the RC10GT Chassis ?
thanks !!
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 10-19-2004, 03:22 PM   #62
Sofast-NT's Avatar
O.S. 12 TR,Trinity Sirio12 Evo 2,Picco.I have a O.S. 12 TR,Runs great,easy to tune,rear exuast,Fasttttttt.
Sofast-NT is offline   Reply With Quote
Old 10-19-2004, 04:03 PM   #63
Wildcherry
Will the gt dogbones and the gt yolk work, what will you gain using trhe t4 instead. And what will you loose using the gt.
D Mac is offline   Reply With Quote
Old 10-19-2004, 04:35 PM   #64
Wildcherry
also using the 3.5 racers hubs, doesnt that give you a total 6.5 toe in in the back?? The a arm carriers come with 3. Not trying to pick trying to understand because I will try this. thanks for bearing with me
dave mac
Old 10-19-2004, 05:00 PM   #65
Trader Rating: 28 (100%+)
The arm carrers come 3 degrees. That makes 6 degrees toe in. The 1.5 hub carriers bring it down to 4.5 toe in. That's stock. Alot of people go with 0 degree hub carriers to get to 3 degrees rear toe in. That helps with any pushing problems in the turns. It's what I use. I think wildcherry has the angle mixed up in his previous posts.
He's talking about widening the rear. So if you don't use the T4 or B4 rear axel, you won't get a widened stance.
jbrow1 is offline   Reply With Quote
Old 10-20-2004, 01:30 AM   #66
Tech Legend
Wild Cherry's Avatar
Sorry for the confusion Dmac & everyone....
* Stock Gt rear hub is 0 degree or 3.0 degree toe
* Team Gt comes with the 1.5 degree rear hub... 4.5 toe
Order the Racer`s Edge Hub for B-4 , be sure you get the 1.5 degree ones...... ( RCE9438>Stomer Hobbies)
Thats all I`m waz trying to say here....( I corrected the 3.5 mistake)
If you use the stock rear hub for the T-4 ,you get 3.0 degree toe.
With this set-up my Gt does not push, If you use the correct choice for the Ft tire.
I`m using losi 8 row, silver, well worn, with standard foam insert & Tangerine Tire grip.....used what tire works best for you....
Remember, use the Rtr axle for the T-4 or B-4( For Dogbones)
*use 7 thin Cvd shims on the axle before you install axle on hub, then use 2 thin shim`s & install the axle pin..
You cannot get the wider rear track with the B-4 rear axle spacer installed. So don`t use it....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 10-20-2004, 01:41 AM   #67
Tech Legend
Originally posted by D Mac
Wildcherry
dmac
The T-4, T-3, GT all use the same size dogbone....( with T-4 & B-4 Rtr rear axle)
And, for its worth , Ae uses different part number`s on the same dogbone......
Even more confusion..... He !
George W. Cherry
Old 10-24-2004, 06:00 PM   #68
Wildcherry
Well the verdict is in. My buddy who holds the record at our local track, put all these mods on this week, and today was about a 1 faster per lap, and broke his fastest lap record by a second.
Although he used t4 front axles, other then that everything was the same, he said it handled like his t4.
Needless to say ill be working on these mose this week.
He is wondering about shiming the ball stud up or down on the caster block? any suggestions
thanks for the help
Daev Mac
Old 10-30-2004, 12:53 PM   #69
Tech Legend
D Mac,
sorry for the delay, rebuilt da puter...
Its almost as fast as a Ae now...
Glad to C you like the set-up...
Switch to the losi axle in ft...
You will be glad you did, with the T-4 axle you are missing alot of steering & stability...
I just brought a new digital (Nikon) ...
Will post pic`s soon.....
ft ball stud >
more up = more steering & less stability
down = less steering & better for bumps
with these changes....
Da Ae Gt is faster than the Losi ,Mugen, ect. !!!
George W. Cherry
Old 11-01-2004, 06:30 AM   #70
beetlebz's Avatar
Send a message via AIM to beetlebz
for those interested, i just got the crescenzi rear widening kit for the GT. its not really much wider than the stock GT, but it incorperates losi style axle washers to prevent the rear CVDs from binding against the bearings. no more meticulous process when tightening down the rear wheels! just turn and go... losi style
beetlebz is offline   Reply With Quote
Old 11-01-2004, 03:30 PM   #71
Now just get the front widening kit and you'll really love it!! I still don't crank my wheel nut down with the new washers either. With the old setup you just tighten the nut, then back off an 1/8.
Old 11-01-2004, 05:20 PM   #72
Wild Cherry
THanks for the reply, I have a couple more questions, hope you dont mind you have been very helpful!!
1. The t4 and the losi mod axle are the same lenth, so tring to understand why the losi is better?
2. THe Losi I read you recomend 5 washers under the ball on the steering arm?? That seems like a huge amount, just wondering why
Again thanks for your help. I think phase two of the losi axles is going to happen this week.
THanks
Dave Mac
Old 11-01-2004, 05:56 PM   #73
LosiFromHell986's Avatar
Send a message via AIM to LosiFromHell986
Since this is the RC10GT thread, I decided to ask. Should I wait to buy a GT for an update, or should I just break down and buy one when I get my job?
LosiFromHell986 is offline   Reply With Quote
Old 11-01-2004, 06:10 PM   #74
Losi, if you want one soon, get one when you get your job. Or hold your breath to see if a new one comes out.
Dave, you guys still racing? Where are you at? Starting some oval carpet cars here now. Fun stuff, but definately not
Moto-X-RC. I don't care what anybody tells me, nothing beats big air!!! Each to their own I guess.
Wild Cherry, can you post some pics of your front and rear axle setup? Mostly the front is what I want to see.
Old 11-01-2004, 06:29 PM   #75
Yeah, I'm just waiting for a T4 suspension-style one to come out, because everytime I buy something, the new version comes out a month later!
Rc10 b4 Factory team evo8guy R/C Items: For Sale/Trade 7 05-08-2008 08:27 AM
FS: Factory Team RC10 GT2 ARR drpeffers R/C Items: For Sale/Trade 12 04-14-2008 09:41 PM
RC10 GT2 Factory Team Kit to be Given Away!! i_like_f150s Georgia Racing 0 09-27-2007 02:02 PM
NEW RC10 GT2 Factory Team Kit darbngreen R/C Items: For Sale/Trade 11 04-10-2007 07:44 PM
rc10 factory team B3 dynasty R/C Items: For Sale/Trade 2 10-07-2004 11:42 AM
