RC10 Factory Team GT???
#46
Well even with the Losi axle, my Gt is still tab less wide than a T-4 ft end....
I gona add a .050 spacer so it comes close ...
And that scub stuff sounds good , but the king pin mod just allows you to use a longer ft camber link > which means more low & high speed steering....
I worked tonight on installing some racer edge rear hubs for the B-4 & T-4 & installed um on my Gt . The set of hubs I purchase has the extra Toe just like the Gt hub & allows me to get a wider rear track, its now as wide as the T-4`s.....
Get to try & race it Tommorow .....Oooo! Boy ! Even more traction....
Aaron,
Well at least there`s still plenty of time to make some improvements......
Aaron,
#48
Originally posted by jbrow1
I was thinking of getting some T4 rear hubs to try out. Don't they have a couple extra camber mount holes also? When you say extra toe, you mean more toe-in like the gt comes with stock?
The Racer`s Hub has even more holes & you can adjust the height of the ball stud for even more tuning(Vertical stud holes) ....
Thats right , the team Gt has 3.5 degree ...
Make sure you replace with same amount of toe. The T-4 hub do not have as much toe I believe( less traction) . Thats why I`m using these Racer Edge hubs, they make one with extra toe.
I did however have to drill the supension pin hole out to 1/8 size...
Going to track track right now , will let you know how all of this worked....
#49
Racer Edge 1.5 hub track report
I installed the hubs & ran them with T-4 dogbones for the first time...
I was amaze by the extra stability & traction...
My lap times were improved by a 1/2 sec per lap !
If you want to make your Gt even faster give this a try ......
You will be very please.....
Remember, you will need to use the Racer`s Edge 1.5 hub & you have to drill out the supension pin hole to 1/8....
The stock Ae T-4 & B-4 hub are only available in 3 degree`s....
Tip: When you install the T-4 dogbones with the T-4 RtR axles you will need to install a plastic spacer(#6440 thick washer) inside each end of the axle & outdrive to space the dogbones so they will not come out.....
Also install 7 of the thin shim`s that come with your Cvd`s for spacing on the end of the T-4 Rtr axle.... Also, do not use the axle spacer from the T-4, unstead just used 2 thin shim`s & a axle pin on the end of the axle where the wheel pin & nut goes on.
#50
Wildcherry
Thanks, for sharing, cant wait to try this.
is that your lap times improved .5 of a second or 1 to 2 seconds.
THanks
Dave mac
THanks
Dave mac
#51
I ran the Gt with out the rear hub last week-end....
lap times were like >>>17.2,17.3,16.9,17.0,16.8,17.2 ect....
This week-end with hubs>>>>17.2,16.6.16.5,17.0,16.4,16.8,16.3 ect....
Trcr is a very consistant surface, so if you go faster it most likely cus you were faster, not the track....
Love the Gt now !
And I loved watching the Losi dudes wonder, what da heck! Is he doing....He !
Later on I will post the complete set-up for everyone..
Love the Gt now !
#52
New setup.
I am Curious how you set your car up? I just changed mine a round to be similar to What myst was suggesting and i ran very Well today. Smacked down a mugen and a slew of losi's! LOL
Looking forward to your post!
#53
tinbndr
nothin better than getting a good slewing in over the week-end....
Team Gt set-up for Trcr......
*indoor track surface
*medium to high traction clay
*medium in size for a indoor facility.
Ft
shocks> Blue,35w,#2
outside on shock tower & outside on ft arm
30 degree caster block that modiflied ,( see above posts)
2 .030 shim under top of ball stud.
bumpsteer > 5 .060 shims
1 degree neg camber for tire
*ft ride height arm level
***losi ft axle install in gt steering knuckle(see above post)
Rear
shocks>green,30w,#1
outside on shock tower & outside on arm
Racer Edge 1.5 B-4 rear hub
inside hole for camber link on hub & top inside hole for bulkhead
( you will need to push the ball end forward on inside camber link to staighten camber rod,I went 3/16)
T-4 Rtr rear axle
T-4 dogbone( T-3 dogbone is same size)
3-2 degree rear arm mounts
rear wheel base for hub >middle
*rear ride height> bones slighlty above level
Tire
ft
Pro-line m2 blades or losi 8 rib silver >both standard foam insert
rear
Proline R-3 evil twin or losi red taper pin >both with proline two stage foam insert...
motor
O.s. Tr .12 , Ae pipe,mip clutch,15t pinion,66t spur gear
body>Proline Silverado
Ft
shocks> Blue,35w,#2
Rear
shocks>green,30w,#1
T-4 Rtr rear axle
Tire
ft
rear
motor
#54
setup
Thanks for the info, I might have to do a little more tweaking.
Our track is pretty rough and very large. outdoor (170X110)
Can you say back straight dragrace!
Anyway I Am not sure that would be the setup for our track but if this other place in town gets going it would perfect!
#55
TnBnDr, This set-up would be so much more stable over the bumps , it would make um feel like they dissappeared.....
You won`t be dissappointed by having the improved traction & best part is the truck will carry better speed though the turns .....No lie, trust me....
Its alot of work, I sould know,but well worth doing.....
best of luck with the slewing....
#56
Rear end
Do you have any pics of the rear end of your car. A picture is worth athousand words.
#57
I wish I had digital, but don`t......
I will get a pic for you by the end of week .....
#58
Pic
Thanks that would be great. In the mean time i will start looking for the parts. i still don't have my front end change either so I will start looking for those parts. Well thats not entirely true the car is widened front and back. and I have changed to losi pistons and limited the shocks.
Look forward to the pics !!
Thanks again for all the info.
#59
Wildcherry
You mean 66 spur, dont you?
#60
Yeah, I looked at the thing upside down & forgot the spur & pinion is 32 pitch...
Sorry....
Sorry....
