Old 01-28-2005, 02:33 PM   #181
Trader Rating: 28 (100%+)
To tell if it hits full throttle just remove the air cleaner (engine not running) and pull the trigger on the radio. If it doesn't open all the way you need to adjust your linkage or epa on the radio. Sometimes you have to rotate the carb in the throat to be able to get full throttle if you don't have end point adjustment on your radio. I've never ran a slide, but making it work should be about the same as a regular.
As for recommending another engine.. What do you have? You could just get a different carb for it if you don't like the slide. As for motors, you can never go wrong with an OS .12, be it a cv,
cv-r, or tr. Novarossi mt .12 is a popular engine also. But alot of people put os carbs on them. OS motors are notorious for being very easy to tune, and staying in tune.
jbrow1 is offline   Reply With Quote
Old 01-28-2005, 03:30 PM   #182
JoshR 85's Avatar
HeY hEy!!!
i have a hpi .12, and it's getting full throttle, it just doesn't feel like it.... and i've heard only good things about os engines, and that there carbs are always the best.... thanx again for help.
JoshR 85 is offline   Reply With Quote
Old 01-28-2005, 04:44 PM   #183
No problem. If it's getting full throttle and doesn't feel like it, it's probably running to rich. Do you temp it ever? If you don't have a temp gun, you can just put a water or spit drop on the head. It should sizzle up in a couple seconds, if not, lean it out a bit.
Old 01-28-2005, 05:53 PM   #184
yodace's Avatar
R/C Tech Charter Subscriber
Originally posted by jbrow1
Yes they are. Email Dave at that site and he'll get ya the info. If not, the parts needed to do it yourself are listed somewhere maybe a page back or so. Dave's is a bolt on mod though. He's a cool guy.
I whated to replace the front bearings.
yodace is offline   Reply With Quote
Old 01-28-2005, 06:26 PM   #185
He still sells his kits. They are just out of stock right now. You can email him and ask him when they'll be in. Or they might even be in and the site wasn't updated yet. So just get in touch with him, he'll hook ya up.
Old 01-31-2005, 07:37 PM   #186
Chris08527's Avatar
Trader Rating: 16 (100%+)
Default steering block trouble???
hey guys,
still working on the GT no rush to get it running with snow on the ground here in jersey
i noticed i have little to no play in my steering it only moves maybe an 1/8th to a 1/4 of an inch and it hits the block, i looked at the directions again and everything looks good
i have no idea what i did wrong, but i know this, i would not be able to make a turn to save my life with the way it is now
any suggestions/help
thanks,
Chris08527
Chris08527 is offline   Reply With Quote
Old 01-31-2005, 08:15 PM   #187
Check to see if you have the left and right mixed up on either the steering arm, or the castor blocks. The angled part of the castor block should face forward I believe.
Old 01-31-2005, 08:24 PM   #188
Chris08527's Avatar
it looks the same as in the manaul pics, i will check though
jbrowl i am just gonna start pm'ing you and keep the forum and my stupid mistakes clean . . .LOL
later,
Chris08527
Old 01-31-2005, 09:27 PM   #189
No problem. Let me know if ya still having a problem.
Old 02-06-2005, 06:11 PM   #190
WHear to you drill the rear camber link to make it longer??
I have seen it done on a aluminun bulkhead, but can you do it on a stock one???
THanks
Dave Mac
D Mac is offline   Reply With Quote
Old 02-06-2005, 06:51 PM   #191
Dave I've looked myself and can see no place that would work on the stock bulkhead. But if you are using the widening kit you could drill another hole on the hub carrier ear. That would be out and down. That might give the same effect as drilling the bulkhead up and in. What does it do for the guys who drill the new hole? What reason do they say they do it for? Does it help spinning out?
Old 02-07-2005, 02:09 PM   #192
Jeff
He said it helped traction, but mostly helped squaring up, and able to carry speed threw a corner better, he said it made a big difference, I got a aluminun bulkhead, Im gonna give it a wirl. Ill let you know.
How did your boys do in Ohio?? Only one guy from here ended up going, he went alone, He bumbed from the E to the C main, came in third in the C main. He is one of the fastest truck drivers in this area.
Im going next year.
Old 02-07-2005, 03:52 PM   #193
Well the local pro finished second in the A-main for gas truck, and 2nd in the A for 1/8 buggy also. Couple other guys placed in the lower mains for MT and 1/8. Just got myself a 1/12 scale to run carpet roadcoarse. Only 2 months or so till dirt season!!!!!!!
Old 02-07-2005, 07:38 PM   #194
Jeff
you must have some super fast local racing.
I bet that running that carpet this winter will help you a bunch in off road, I have noticed the guys that are real good around here have some on road experience to.
Old 02-07-2005, 07:45 PM   #195
Jeff
Just courios, is Allen a sponcered driver, and what type of truck does he run.
thanks
d mac
Rc10 b4 Factory team evo8guy R/C Items: For Sale/Trade 7 05-08-2008 08:27 AM
FS: Factory Team RC10 GT2 ARR drpeffers R/C Items: For Sale/Trade 12 04-14-2008 09:41 PM
RC10 GT2 Factory Team Kit to be Given Away!! i_like_f150s Georgia Racing 0 09-27-2007 02:02 PM
NEW RC10 GT2 Factory Team Kit darbngreen R/C Items: For Sale/Trade 11 04-10-2007 07:44 PM
rc10 factory team B3 dynasty R/C Items: For Sale/Trade 2 10-07-2004 11:42 AM
