Old 09-27-2004, 07:52 PM   #1
Rysuleod's Avatar
Default Caster and toe in
I have a Losi MF2 and I am attempting to set it up at the recommended specs. It calls for 1 degree of camber and 1 degree of toe in.
Is there a trick to making these small measurements with big offroad tires attached?
Thanks,
Rys
Rysuleod is offline   Reply With Quote
Old 09-27-2004, 08:05 PM   #2
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
The Trick?......good eyes usually. Get an RPM camber gague and always set your camber on a very flat surface. For the most accurate measurement, you should always have some empty rims lying around. When the tire is off the rim, it is very easy to make accurate adjustments because you're measuring the angle of the rim and not the balloon of the tire. For toe in, thats purely an eyeball measurement. However it is always easiest to measure toe in and make it equal when the car is on so that the servo is centered. Also, look at the toe from behind the car.
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 09-28-2004, 12:17 AM   #3
Aaron Waldron's Avatar
You can use that camber gauge to measure toe as well. Park the truck next to a wall, and put the gauge on the wall so it's perpendicular to the ground.
Like this:
|____0-----0_________
Make sure each tire has 1/2 degree.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 09-28-2004, 05:08 PM   #4
Rysuleod's Avatar
Thanks guys. I'll definitely use those ideas.
I have to give my driver half a chance to drive the thing straight! We took the MF2 out for its virgin run and got one run in on Sunday. The driver (my step son) hit the wall so hard on the left rear tire that it tore the A arm hinge pin out of the socket and we spent the rest of the track time fixing it! He's not wise to the fact that the camber and toe in were goofy. No one is allowed to tell!
Rys
Old 09-28-2004, 05:39 PM   #5
kvrc's Avatar
RPM also makes a toe guage. Aarons way will work also, but i think the toe guage is eaiser to work with.
kvrc is offline   Reply With Quote
Old 09-28-2004, 06:10 PM   #6
BatJam1's Avatar
I find setting by B-4's 1deg. toe out with the car on and with a new set of rim's only no tires, then measure the rims front outer edge then measure your rear outer edge and make adjustments accordingly! for camber i use the RPM guage -1 1/2 DEG. For caster it depends on track conditions and layout !then i'll use the appropriate caster block!
BatJam1 is offline   Reply With Quote
Old 10-01-2004, 05:42 AM   #7
We have been using old CD's glued together as set up wheels. it makes measuring the camber and toe in much easier.
Bob The Builder is offline   Reply With Quote
caster ??? FireDoc Oval, Larger Scales and More 6 09-03-2008 05:55 PM
Caster ZX-1R PRO Roller manynitros R/C Items: For Sale/Trade 3 08-08-2008 09:10 AM
Caster ZX-1 PRO New manynitros R/C Items: For Sale/Trade 5 06-25-2008 10:21 PM
FS: NEVER RUN CASTER BUGGY dgraham225 R/C Items: For Sale/Trade 6 02-14-2008 07:36 PM
caster?? odawg315 Electric On-Road 22 07-08-2005 01:17 PM
