Tekin Redline solderering posts & warranty? >
Old 05-16-2011, 04:59 AM
dj_sparky's Avatar
Default Tekin Redline solderering posts & warranty?
I'm having some trouble soldering the wires to the posts on this motor, it's already broken off once and I haven't driven it yet. What happens if it fries because of this? Will the warranty replace the destroyed items?
There should be a loop or some connectors to really get a good hold imo.
dj_sparky is offline
Old 05-16-2011, 06:55 AM
BMenard17's Avatar
Trader Rating: 88 (99%+)
I have had several tekin motors and never had one break or even look stressed. Tekins warranty is great from my experience but dont know if they will warranty neglect. It sounds like you need to take better care of you stuff..
BMenard17 is offline
Old 05-16-2011, 07:42 AM
lowroad's Avatar
Trader Rating: 79 (100%+)
how do you break one without driving it?
Maybe rethink you're handling and/or soldering techniques.
lowroad is offline
Old 05-16-2011, 07:51 AM
I have a similar question to above. I have had 5 Tekin systems and never broken a solder tab; let alone without driving the vehicle. My only gripe is I wish they were a little farther apart. Sounds like you may be doing something wrong that's causing the tabs to be damaged.
AMorgan is offline
Old 05-16-2011, 08:11 AM
Team Tekin
Randy_Pike's Avatar
Yeah, solder tabs don't usually break, ever. What motor is it?
Randy_Pike is offline
Old 05-16-2011, 08:14 AM
Odin544's Avatar
Trader Rating: 93 (100%+)
Originally Posted by dj_sparky View Post
I've noticed that the soldering posts on these motors are really weak, it's already broken off once and I haven't driven it yet. What happens if it fries because of this? Will the warranty replace the destroyed items?
Do you use a crappy soldering iron?
Odin544 is offline
Old 05-16-2011, 08:34 AM
dj_sparky's Avatar
Sorry, I meant that the solder point broke off, not the post. The only thing that's holding it together is a piece of solder, and it doesn't look like it could handle 1 tug.
Could it be that I need to use a different kind of solder?
Old 05-16-2011, 09:04 AM
UK.hardcore's Avatar
Depends, what you use now?
UK.hardcore is offline
Old 05-16-2011, 10:22 AM
michael mercer's Avatar
How bout a picture. I'm sure there's a solution to your problem.
michael mercer is offline
Old 05-16-2011, 05:17 PM
Sounds like a cold joint. Start here:
http://www.teamnovak.com/tech_info/h...der/index.html
I always thought I could solder until I started researching. I was way off and basically getting lucky. Also check YouTube, tekin has some videos swell as some experts. Worth a million bucks.
Chip73 is offline
Old 05-16-2011, 05:58 PM
BMenard17's Avatar
sorry for my first post... sounds like all you need is some soldiering advice, If I were you I would do a youtube search. The best way to learn is to watch IMO.
